Old 02-25-2008, 08:47 AM
Micha Micha is offline
Manipulating Tracker View
Hi There,
I use an Ascension FOB and I want to change the main view, i.g. rotate around the z-axis, so that the view for example looks always 90 deg rotated to the actual tracking view.
Any Ideas?
Thanks, Mike
Old 02-25-2008, 09:50 AM
Ok, I got it!
data = tracker.get()
	view.reset(viz.BODY_ORI)
view.setEuler(data[3]+180,data[4],data[5], viz.BODY_ORI, viz.ABS_LOCAL)
Old 02-25-2008, 11:00 AM
You can also use a link to have Vizard automatically perform this operation for you. Example:
headLink = viz.link(tracker,viz.MainView,dstFlag=viz.LINK_BODY)
headLink.postEuler([180,0,0],target=viz.LINK_ORI_OP)
Old 02-25-2008, 11:05 AM
Nice, thank you very much, works perfectly!!
Cheers Mike
Interface with Tobii Eye Tracker Uttama_vizard Precision Position Tracker (PPT) 1 12-12-2007 12:31 PM
Can Vizard interact with the Arrington eye tracker? Deltcho Vizard 1 09-18-2007 03:38 PM
problem with stereo mode shivanangel Vizard 3 10-17-2006 10:58 AM
Moving view with object Xliben Vizard 2 07-25-2005 06:36 PM
keeping a 3d object in front of the view tavaksai Vizard 1 07-07-2004 10:33 AM
