Old 07-21-2005, 05:53 PM
Xliben Xliben is offline
Moving view with object
Ok, this is probably going to sound REALLY dumb so excuse me but I am new to Vizard.
What I would like to is make it so when I have a Wheelbarrow move the camera stays behind it at a specified distance. I currently only have the Wheelbarrow moving (and that doesn't even completely work seeing as when I move forward or backwards meanwhile turning the object slows down and goes for twice the time it should); anyway, I have tried nearly everything I could find but nothing seems to work so... heres what I have... it doesn't work at all so any assistance what so ever would be soooooooooo helpful.
BTW to anyone who cares this is going to be used for a game prototype so any additional information would be much appreciated.
Most of the script below has been derived from tutorials within the trial version. Thanks
viz.mouse(viz.OFF)
viz.add('tut_ground.wrl')
Wheelbarrow = viz.add('wheelbarrow.ive')
UPDATE_RATE = 0.001
view = viz.add(viz.VIEWPOINT)
Wheelbarrow.translate(0,0,6)
MOVE_SPEED = 10
TURN_SPEED = 360
MOVE_FORWARD = vizact.move(0,0,MOVE_SPEED,.01)
MOVE_BACKWARD = vizact.move(0,0,-MOVE_SPEED,.01)
TURN_RIGHT = vizact.spin(0,1,0,TURN_SPEED,.01)
TURN_LEFT = vizact.spin(0,-1,0,TURN_SPEED,.01)
def mytimer (num1):
if viz.iskeydown(viz.KEY_UP):
Wheelbarrow.add(MOVE_FORWARD)
elif viz.iskeydown(viz.KEY_DOWN):
Wheelbarrow.add(MOVE_BACKWARD)
Wheelbarrow.add(TURN_RIGHT)
Wheelbarrow.add(TURN_LEFT)
viz.starttimer(1,0.01,viz.PERPETUAL)
def updateview(num1):
POS = Wheelbarrow.get(viz.POSITION)
view.goto([viz.get(Wheelbarrow.get(viz.POSITION))],5,5)
Old 07-25-2005, 01:15 PM
I've modified your script a little to do what I believe you want it to do. I've commented the parts of the code that modify the viewpoint. Let me know if this isn't exactly what you are looking for.
viz.mouse(viz.OFF)
#Get handle to main viewpoint
MOVE_SPEED = 10
TURN_SPEED = 360
def mytimer(num1):
	#Move wheelbarrow using arrow keys
		Wheelbarrow.translate(0,0,MOVE_SPEED*viz.elapsed(),viz.RELATIVE_LOCAL)
		Wheelbarrow.translate(0,0,-MOVE_SPEED*viz.elapsed(),viz.RELATIVE_LOCAL)
		Wheelbarrow.rotate(0,1,0,TURN_SPEED*viz.elapsed(),viz.RELATIVE_LOCAL)
		Wheelbarrow.rotate(0,1,0,-TURN_SPEED*viz.elapsed(),viz.RELATIVE_LOCAL)
	#Create transform from wheelbarrow
	xform = viz.Transform(Wheelbarrow.get(viz.MATRIX))
	#Move position up 1 meter and back 5 meters
	xform.preTrans(0,1,-5)
	#Apply position of transform to viewpoint
	view.translate(xform.getTrans())
	#Have viewpoint look at wheelbarrow
	view.lookat(Wheelbarrow.get(viz.POSITION))
viz.starttimer(1,0,viz.PERPETUAL)
Old 07-25-2005, 06:36 PM
Thanks a million it looks great!
