Old 06-15-2018, 12:01 PM
hannahapz hannahapz is offline
Stop avatar from walking to its destination
I'm fairly new to Python and Vizard, so the answer to this may be strikingly obvious to some.
I'm trying to stop my pedestrian avatar from walking to a final location as soon as I enter within the bounds of its proximity sensor.
My current code is as follows You can assume I've done all necessary module imports:
def set_avatar_proximity_sensor():
	global manager, sensor
	manager.setDebug(viz.ON)
	target = vizproximity.Target(Me)
	manager.addTarget(target)
	sensor = vizproximity.addBoundingSphereSensor(pedestrian,scale=2)
	manager.addSensor(sensor)
	vizact.onkeydown('d',manager.setDebug,viz.TOGGLE)
def pedestrian_actions():
	runAction = vizact.walkTo( [-12, 0, 3] )
	pedestrian.addAction (runAction)
def enter_proximity(e):
vizact.ontimer(0, pedestrian_actions)
manager.onEnter(sensor, enter_proximity)
So, right now, the enter_proximity function is obeyed only after the pedestrian_action function has ended. How do I interrupt the pedestrian_action function however?
Old 06-15-2018, 06:27 PM
I've been able to stop the animation of the avatar's body using an if statement, but otherwise have not been able to stop the avatar's trajectory to a destination.
Old 06-15-2018, 09:38 PM
Solved
I solved the issue with a simple if-elif statement
	ped_position = pedestrian.getPosition()
	car_position = car.getPosition()
	distance = vizmat.Distance(ped_position, car_position)
	print(distance)
	if distance > 4:
	elif distance < 2:
		pedestrian.clearActions()
avatar walking backward sbilleter Vizard 1 09-18-2015 12:26 PM
Walking Animation of Avatar pradeep Vizard 1 07-03-2014 04:35 AM
How to simulate avatar walking along a slanted surface Zhi Vizard 3 11-21-2013 05:27 PM
walking of avatar via patriot Veronika Vizard 6 10-07-2011 01:33 AM
avatar walking over a sequence of points IGoudt Vizard 1 10-16-2009 12:22 PM
