Old 11-12-2013, 03:16 PM
Zhi Zhi is offline
How to simulate avatar walking along a slanted surface
Apparently, the vizact.walkTo() method only allows the avatar to walk along a horizontal surface. If I want to simulate avatar walking along a slanted surface (such as a hill), what shall I do. Moreover, if the ground surface is uneven (i.e. with different local height), how to keep the avatar always contacting the ground surface.
Please help me! Thanks!
Old 11-15-2013, 04:48 PM
You can pass the ground object as the height value:
ground = viz.add('ground.osgb',euler=[0,20,0])
avatar = viz.addAvatar('vcc_male2.cfg')
walk = vizact.walkTo([0,ground,10])
avatar.runAction(walk)
viz.MainView.setPosition([10,0,5])
viz.MainView.setEuler([-90,0,0])
Old 11-21-2013, 10:04 AM
Zhi Zhi is offline
Thank you Jeff. It works if the ground is an imported 3D model (i.e. a .osgb file). But if I create an object on the fly (for example, using the viz.addTexQuad() method), it seems your way does not work. Is it possible to let the avatar to follow the surface of an on-the-fly object?
Old 11-21-2013, 05:27 PM
It should still work if you add a quad. Try the following:
ground = viz.addTexQuad(scale=[50]*3,euler=[0,80,0])
walking of avatar via patriot Veronika Vizard 6 10-07-2011 01:33 AM
Avatar walking + camera free look kovitch Vizard 2 08-08-2011 08:57 AM
avatar walking over a sequence of points IGoudt Vizard 1 10-16-2009 12:22 PM
avatar automatically runs animation after fading into view v-clizzin Vizard 1 10-14-2009 06:01 PM
