Old 09-01-2016, 06:20 AM
It's difficult to say without being able to run code that reproduces the issue. If the display frame rate is stable then it seems like something in the code is causing this. Both of these methods to move the viewpoint work fine in other examples. Are you able to run your code and perhaps simulate treadmill values rather than actually doing any IO operations?
animation path problem - coordinates not resetting jelly Vizard 7 04-26-2016 10:45 AM
Using Oculus and Vicon for updating in pit Qiliang He Vizard 1 09-06-2015 02:46 PM
Prevent Oculus DK2 updating the view with accelerometer info Notch Vizard 3 10-24-2014 11:06 AM
View nlfrnassimi Vizard 4 03-12-2009 05:25 AM
problem with stereo mode shivanangel Vizard 3 10-17-2006 09:58 AM
