Old 09-06-2015, 09:36 AM
Qiliang He Qiliang He is offline
Using Oculus and Vicon for updating in pit
I have troubling using Oculus DK2 for orientation updating and Vicon for position updating in pit. The following is the snippet of codes I use for updating
HTML Code:
def UpdateView():
    p = pos.getPosition() ##use Vicon for position updating
    x = -p[1]/1000  ## position conversion
    y = p[2]/1000
    z = p[0]/1000
    o = sensor.getEuler() ##use Oculus for orientation updating
    viz.MainView.setEuler(o[0], o[1], o[2],viz.BODY_ORI)
    viz.MainView.setPosition(x,y,z,viz.HEAD_POS) ##set the position
vizact.ontimer(0,UpdateView)
The orientation updating is OK but not the position. I have to comment the following codes to make the position tracking work
HTML Code:
faller = PitTrackedFaller(head_tracker)
viz.link(faller,viz.MainView)
However, this disables the faller. When can I do in this case? Thank you!
Old 09-06-2015, 03:46 PM
I just figure out. All I need to do is replace the
with
head_tracker.setPosition(x,1.5,z,viz.HEAD_POS)
oculus, pit, vicon
oculus DK2 in vizard 5 green951 Vizard 1 06-18-2015 09:12 AM
