Old 07-28-2015, 10:33 PM
rajnish_xenium rajnish_xenium is offline
Smile Regarding Corner Cave in Vizard 5 using PPT-E System on a remote machine
Hi Jeff..thanx for the referene for Viz Connect..
I got the want connected to the viz connect using Vizard 5... i also got the Status of Wand&Signal and datas of Yaw roll and pitch.. in the VizConnect...
My Prset configuration Script...which was
..A Corner Caven with PPT Configuration..
i got the a Preset Configuration Script...and i saved as ..'corner_cave.py' file..instead of 'vizconnect_config.py'..
The code of 'corner_cave.py' file is...
Now i want to create a script in which i want to get the wand signals and Button data and inputs data..in my newly created script..suppose..'navigation.py' in which ill move my viewpoint with refrefence to Wand JoyStick and Button Data and Inputs Data..from The wand which is active in VizConnect Window...
...Jeff please help me to achieve this...as i m alone working on it..and i will do it..
I want to create another script..in whioch i should navigate my ViewPoint with the help of wand..
I know that ..
In my newly script.'navigation.py'..
i have to write..the line as well
code:
import vizconnect
vizconnect.go('vizconnect_config.py')
or:
# load vizconnect configuration file
import vizconnect
#get a handle to the input by name
input = vizconnect.getInput('mouse_buttons')
or:
import vizconnect
keyTracker = vizconnect.getTracker('keyboard').getNode3d()
Please help me with exact code of wand helping me to move my Viewpoint...
Waiting for ur reply Jeff..Thanx..for the last help..Thanx a lot...
Mr.Rajnish Vishwakarma(Developer at Xenium Digital Pvt Ltd)
..Waiting for ur reply..
Properly aligning the intersense with the PPT Systems Z Axis shivanangel Precision Position Tracker (PPT) 0 11-10-2009 11:35 AM
world is tilting - intersense or code problem? billjarrold Vizard 2 11-06-2009 08:03 AM
intersense with 5DT glove sjp Vizard 2 04-06-2009 07:22 AM
using demo with intersense G-Chan Vizard 1 02-06-2006 02:05 PM
intersense orientation jargon Vizard 2 05-14-2005 04:55 PM
