Old 06-02-2015, 11:00 AM
vlc vlc is offline
Hi Jeff,
Computer A has the IS900, however I want Computer B to be able to connect to the tracker on the IS900 using VRPN. I know that you mentioned in other posts how to create the stream, but my question is: how do you actually obtain the data from the stream. If Computer A has the VRPN stream running, how would I get that data from the stream using computer B. Does that make sense?
intersense, vizard 4, vrpn
Exposing an intersense cube via VRPN nihohit Precision Position Tracker (PPT) 5 09-10-2012 04:00 PM
intersense addTracker krimble Vizard 4 04-02-2012 09:57 AM
VRPN quaternion conversion from PPT from Intersense InertiaCube willemsn Precision Position Tracker (PPT) 0 07-20-2011 01:59 PM
