Old 09-06-2012, 12:36 PM
nihohit nihohit is offline
Exposing an intersense cube via VRPN
I'm trying to set up PPT's MoCap plugin, but I'm a bit confused.
The way we are setup is that we have two machines, call them A and B - one with the Intersense cube attached to it (well, the cube is on a helmet attached to the machine) and the other running PPT Studio. The two machines are connected via ethernet.
As far as I understand, I need to have a VRPN server running on machine A so that the VRPN Input plugin on machine B can read from it. Is this correct?
If so, how do I expose this functionality? Machine B does have Vizard, if I'm missing something there. Otherwise, I have tried to download the actual VRPN server from here: http://www.cs.unc.edu/Research/vrpn/ but I've found a dearth of data on how to configure that server so as to expose the Intersense cube. Does anybody here know?
Thank you.
Old 09-07-2012, 05:10 PM
With the VRPN plug-in in Vizard you can create a server to stream the Intersense data:
#Add VRPN extension
vrpn = viz.add('vrpn7.dle')
#Create a server
server = vrpn.addTrackerServer('VizardTracker')
#Get the Intersense tracker
isense = viz.add('intersense.dle')
tracker = isense.addTracker()
#Set tracker that server uses
server.setTracker(tracker)
In PPT, specify the VRPN server when you configure the VRPN input plug-in. Here that would be:
VizardTracker@Render-PC
where Render-PC is the name of the machine running Vizard.
If the script is not running and streaming data you'll see error messages in PPT Studio when the VRPN Input plug-in is added.
Old 09-09-2012, 03:26 AM
Thank you very much, that solved the problem.
Is there any way I can run this server "in the background", so that I don't get errors on the ppt machine whenever my main script isn't running?
Currently, it looks like worldviz can only run one script at a time.
Old 09-09-2012, 12:20 PM
If the error message is showing up in PPT Studio before running the script it's not a problem. You probably want to clear the message after the script starts so you can see if anything happens while it's running.
Old 09-09-2012, 02:17 PM
Well, no, the error showing up is that it's not receiving intersense input - not surprising.
Doesn't that hurt the initial calibration I did in MoCap if the server keeps going on and off?
Old 09-10-2012, 05:00 PM
That should be fine. The initial mocap calibration will not be affected if the stream is interrupted.
intersense addTracker krimble Vizard 4 04-02-2012 10:57 AM
VRPN quaternion conversion from PPT from Intersense InertiaCube willemsn Precision Position Tracker (PPT) 0 07-20-2011 02:59 PM
Properly aligning the intersense with the PPT Systems Z Axis shivanangel Precision Position Tracker (PPT) 0 11-10-2009 12:35 PM
world is tilting - intersense or code problem? billjarrold Vizard 2 11-06-2009 09:03 AM
intersense with 5DT glove sjp Vizard 2 04-06-2009 08:22 AM
