Old 10-09-2014, 12:37 PM
brunomartelli brunomartelli is offline
how to do a 2 screen CAVE setup for gallery?
Hi
I'm converting a 3 wall and floor CAVE environment to 2 screen for an art show. I'd like it configured like the image:
There is a physical wheel controller to drive the installation.
I would like to use one PC to drive the 2 projectors. How to set this up in Vizard? Any pointers please? My pc will run 2 monitors with Vizard fullscreen on both but the perspective needs tweaking because of the leaning screen. Is it some special setup in Vizconnect?
Old 10-10-2014, 10:27 AM
So i can get Vizard to drive 2 monitors, but how to get it to display different cave walls on each monitor? At the moment it stretches 1 view over both
Old 10-10-2014, 10:40 AM
Have a look at the vizcave single machine example script. It shows how to create multiple subwindows and assign a wall to each window.
Old 10-13-2014, 07:27 AM
ok!! that seems to be what to do!! but *please* for the sake of my numberlexic brain could you explain what WINDOW_SIZE should be set for the 2 windows I want, 1 above the other...
Old 10-13-2014, 11:42 AM
ok I figured it out, I am a GOD!!!!!
Old 10-13-2014, 01:21 PM
Also in that example file, when i added
viz.go(viz.FULLSCREEN |viz.QUAD_BUFFER)
only center widow was stereo, so I had to tell the other windows to be stereo like this:
leftWindow = viz.addWindow(size=WINDOW_SIZE,pos=[0,1])
leftWindow.stereo(viz.QUAD_BUFFER)
cave.addWall(LeftWall,window=leftWindow)
2 screen, cave
Vizard exits full screen after 30 seconds derek Vizard 3 08-21-2014 12:02 PM
CAVE screen lag brunomartelli Vizard 7 07-19-2013 10:36 AM
[New here] Cave joy navigation esuna114 Vizard 2 06-11-2010 04:36 PM
Flipped floor in a CAVE shivanangel Vizard 1 03-10-2010 10:12 AM
right-hand to left-hand coordinate System for a cave setup Andy Vizard 1 09-16-2009 10:17 AM
