Old 06-10-2010, 10:12 AM
esuna114 esuna114 is offline
[New here] Cave joy navigation
Hello everybody,
I'm very new to Vizard, so maybe my questions will be stupid.
Right now i've got a problem with joystick navigation in my cave. I've tried to make it from examples. (We have no tracking devices for now)
Here is the cave file:
# The same script must be run on all machines in the cluster
import vizcave
import viztracker
# Activate full screen on all nodes with quad buffering
# Disable the mouse cursor visibility on all machines except the master
viz.cluster.setMask(viz.ALLCLIENTS & ~viz.MASTER)
viz.setOption('viz.fullscreen',1)
viz.setOption('viz.stereo',viz.QUAD_BUFFER)
viz.mouse.setVisible(viz.OFF)
viz.cluster.setMask(viz.ALLCLIENTS)
# Declare constants defining the CAVE dimensions
W1 = 3.048			# wideness 	(X)
H1 = 2.286			# height	(Y)
D1 = 0.56			# deepnees 	(Z)
C0 = -2,2.25,2      # Front  Wall: C0,C1,C2,C3
C1 = 2,2.25,2      # Roof   Wall: C4,C5,C0,C1
C2 = -2,0,2
C3 = 2,0,2
C4 = -2,3.9736,0.5537
C5 = 2,3.9736,0.5537
#Create front wall
FrontWall = vizcave.Wall(   upperLeft=C0,
                            upperRight=C1,
                            lowerLeft=C2,
                            lowerRight=C3,
                            name='Front Wall' )
#Create left wall
RoofWall  = vizcave.Wall(   upperLeft=C4,
                            upperRight=C5,
                            lowerLeft=C0,
                            lowerRight=C1,
                            name='Roof Wall' )
#Initialize graphics window
#Create cave object
LITE = vizcave.Cave()
#Add each wall, make sure that they are ordered in the cluster software correctly to match this ordering
LITE.addWall(FrontWall, mask=viz.CLIENT2)
LITE.addWall(RoofWall, mask=viz.CLIENT1)
import joyLITE
#Create tracker object using the keyboard (WASD keys control the viewpoint, the user's eye location)
#Make the starting location for the user's eye the exact center of the CAVE
viewtracker = viztracker.KeyboardPos()
viewtracker.setPosition (0,1.7,0)
#Pass the viewpoint tracker into the cave object so it can be automatically updated
LITE.setTracker(pos=viewtracker)
#Create CaveView object for manipulating the entire cave environment
#The caveorigin is a node that can be adjusted to move the entire cave around the virtual environment
caveorigin = vizcave.CaveView(viewtracker)
#Create another tracker using the keyboard and mouse (arrow keys adjust position, mouse changes orientation)
#origintracker = viztracker.KeyboardMouse6DOF()
#originlink = viz.link (origintracker, caveorigin)
#Set the MainView in a good position
vpos= caveorigin.getPosition()
viz.MainView.setPosition(vpos,viz.BODY_ORI)
vrot= caveorigin.getEuler()
viz.MainView.setEuler(vrot,viz.BODY_ORI)
#viz.MainView.setEuler(-90,0,0,viz.BODY_EULER)
#FOR LINKS: FIRST: DESTINATION, SECOND:SOURCE
originlink = viz.link ( caveorigin,viz.MainView)
#caveorigin.parent(viz.MainView)
#Link the keyboard/mouse so that it moves the cave and user around the virtual environment
#Add gallery environment model
And here is my joy navigation device ( joyLITE )
#Import the vizjoy module and add one joystick.
import vizjoy
joy = vizjoy.add()
def update_joystick():
	node3d = viz.MainView
	#Get the joystick position
	x,y,z = joy.getPosition()
	#Get the twist of the joystick
	twist = joy.getTwist()
	slider = joy.getSlider()
	state = joy.getButtonState()
	#Move the viewpoint forward/
	#backward based on y-axis value
	#Make sure value is above a certain
	#threshold.
	if abs(x) > 0.2:
		node3d.move(0,0,x*0.01,viz.BODY_ORI)
	#Move the viewpoint left/right based
	#on x-axis value. Make sure value is
	#above a certain threshold
	if abs(y) > 0.2:
		node3d.move(y*0.01,0,0,viz.BODY_ORI)
	#Turn the viewpoint left/right based
	#on twist value. Make sure value is
	#above a certain threshold.
	if abs(slider) > 0.2:
		node3d.rotate(0,1,0,slider,viz.BODY_ORI,viz.ABS_LOCAL)
	if abs(twist) > 0.2:
		node3d.rotate(1,0,0,twist,viz.BODY_ORI,viz.ABS_LOCAL)
	#Up/down with buttons
	if state & vizjoy.BUTTON6:
		node3d.move(0,0.01,0,viz.BODY_ORI)
	if state & vizjoy.BUTTON8:
		node3d.move(0,-0.01,0,viz.BODY_ORI)
#UpdateJoystick every frame
vizact.ontimer(0,update_joystick)
The rotations are very weird, and the view won't translate at all, why so?
I tried my joystick navigation file with another non-cave demo and it worked well.
Thank you by advance.
Old 06-11-2010, 10:07 AM
Nobody could give me a hint?
Thanks.
Old 06-11-2010, 05:36 PM
If you are using the keyboard to update the projections and the joystick to drive the CAVE around you can do something like this.
viewtracker.setPosition (W/2.0,H/2.0,D/2.0)
cave.setTracker(pos=viewtracker)
#update caveorigin with joystick
MOVE_SPEED = 5 # meters/sec
def joyMove():
	#Use y position of joystick to drive CAVE forward
	forwardMovement = viz.elapsed() * MOVE_SPEED * -joyPOS[1]
	caveorigin.setPosition([0,0,forwardMovement],viz.REL_LOCAL)
	#Use x position of joystick to drive CAVE side to side
	sideMovement = viz.elapsed() * MOVE_SPEED * joyPOS[0]
	caveorigin.setPosition([sideMovement,0,0],viz.REL_LOCAL)
vizact.ontimer(0, joyMove)
When using the vizcave module the viewpoint should not be updated with:
viz.MainView.setPosition()
The viewpoint will update properly if you set a tracker for the CAVE and use the CaveOrigin object to drive the CAVE around.
Mouselook & Keyboard Navigation EnvisMJ Vizard 9 06-22-2010 05:52 PM
Flipped floor in a CAVE shivanangel Vizard 1 03-10-2010 11:12 AM
CAVE, navigation, tracked wand, coordinate systems JimC Vizard 6 10-09-2009 01:43 PM
right-hand to left-hand coordinate System for a cave setup Andy Vizard 1 09-16-2009 11:17 AM
navigation in cave environment Andy Vizard 4 03-28-2008 02:32 AM
