Old 06-26-2014, 01:22 AM
Shweta Shweta is offline
Rotation and Translation
Is it possible to control the speed of motion during rotation or translation when we change the viewpoint using setPosition() or setEuler()?
Is there a method to implement the default behavior of using a mouse to move around through matrices (transformation matrix with 6 DOF)?
If yes, how do I control the speed there?
Thanks and Regards,
Shweta.
Old 06-30-2014, 12:45 PM
You can scale the mouse movements using the <viz:mouse>.setScale command. Does that help answer your questions?
Old 07-01-2014, 06:07 AM
Thank you for the reply.
I want to implement the navigation through the window using matrices(without using the mouse. But I also want to control the speed of navigation).
At this point I am using the following code snippet:
(for translation)
gotoRight = vizact.goto([2,1,-2],3,mode =viz.SPEED,rotate_mode=viz.BLEND_ROTATE,ori_mask=v iz.BODY_ORI)
court.addAction(gotoRight)
(for rotation)
spinToYaw90 = vizact.spinTo(euler=[90,0,0], speed=5)
court.addAction(spinTOYaw90)
court.addAction(spinToYaw90)
Now if I want to implement both translation and rotation simultaneously, can I do that?
I tried using setPosition() and setEuler(). However these two commands change the positions within the blink of an eye. Can I slow down the speed with which they impact the scene?
Thanks and Regards,
Shweta Shitole
Introducing a rotation offset into a link EnvisMJ Vizard 1 11-13-2013 06:51 AM
Custom Joystick Rotation mhead10 Vizard 9 11-26-2012 01:06 PM
