Old 05-03-2011, 12:20 PM
You can create a texture with alpha channel so that part of the texture is transparent.
To just make a certain color transparent you could do this with a simple shader. Take a look at the alphaMap example in the docs and the alphaMapper.frag program it uses for some ideas. Also, if you have Vizard 4 installed the shader documentation has been updated and may be helpful.
Missing textures in an executable Dave Vizard 7 10-22-2010 07:59 AM
Textures Scrambled lionfish Vizard 3 02-26-2010 01:42 AM
Multiple Textures for Diffuse and Specularity Shader Issue shivanangel Vizard 1 05-11-2009 10:44 AM
Max -> Vizard, Two Sided Textures shivanangel Vizard 5 12-04-2008 03:15 AM
number of textures to load lucalatini Vizard 2 05-12-2005 05:50 PM
