Old 06-17-2009, 07:46 AM
DrMothra DrMothra is offline
Apologies for taking so long to get back to you, I've only just started looking at this again today after being swamped with other work. I can get the volume to alter accordingly with the example that you posted, but I still have the same query, but I think that I can explain it a little more coherently now. Essentially if I set the volume of an object to 1 (max) and move away from the object the sound is still attenuated, this sort of makes sense - the object is playing at its maximum volume but I'm too far away to hear it. I would really like greater control over the sound than this, hence why I referred to overriding the sound level previously. So I still have some level of attenuation regardless of what calculated volume level I arrive at. I can compensate for this to a degree by adjusting my formula to take the attenuation into account, but I can't get rid of it completely. In actual fact I can still get the kind of effect I was after so it's OK, but would be good if I could stop the default attenuation completely. Thanks for all your help thus far.
Sound Looping Problem JMOwens Vizard 4 09-29-2010 09:42 PM
HRTF-based spatial audio with Vizard? bernie Vizard 4 10-16-2008 09:58 AM
On click Sound Play Problems Robbos Vizard 1 02-28-2008 02:02 PM
Stuttering sound Jerry Vizard 1 06-13-2007 12:36 PM
sound problem alaa Vizard 7 09-02-2005 01:13 PM
