Old 05-18-2009, 03:38 PM
If you just want to apply a global offset to the position of the tracker, then you can specify this when creating a link using the tracker. For example, if you wanted to move the Y position up 2 meters when linking the tracker to the viewpoint, you would use the following code:
viewLink = viz.link(tracker,viz.MainView,offset=(0,2,0))
viz.vertex coordinates lilio Vizard 6 05-16-2009 05:36 PM
Simple Head Tracker PHart Vizard 1 05-10-2009 06:35 PM
Does the vrpn7.dle tracker plug-in clear the udp buffer? michaelrepucci Vizard 2 09-19-2008 11:22 AM
Interface with Tobii Eye Tracker Uttama_vizard Precision Position Tracker (PPT) 1 12-12-2007 12:31 PM
Locating the Coordinates of Vertices for on the fly objects shivanangel Vizard 4 10-30-2006 09:28 PM
