Old 05-07-2009, 07:22 AM
spdegabrielle spdegabrielle is offline
collideNone() failing to stop collision
Hi, I'm using object.collideNone() to stop the viewer from colliding with 'ghost' objects in our maze - but it still seems to collide. (with weird jumpy/falling results)
I don't want to set <viewpoint>.collision(viz.OFF), as this stops the viewer from walking through walls.
I'm sure this must be in the documentation somewhere - but I can't find it.
Any suggestions?
Old 05-07-2009, 09:11 AM
Found it
mazeObject.disable(viz.COLLISION)
will stop the viewer from bumping into an object.
object.collideNone() no effect - I assume it is just for the objects benefit.
s.
Old 05-07-2009, 09:21 AM
disable(vis.COLLISION) is not mentioned anywhere in the manuals.
[vis.INTERSECTION gets a mention under node3d.disable - but not vis.COLLISION]
Old 05-07-2009, 01:35 PM
Maintaining up to date docs is a challenging task for Vizard (or any 3D engine). Is certainly no excuse of course.
I work with the viz.py and vizact.py files open in Vizard and constantly reference them as I code. It's one of the benefits of Vizard's openish architecture.
The object.collideNone() function removes rigid body physics shapes from a node. A separate system from the viz.COLLISION stuff.
Paul Elliott
WorldViz LLC
Collision detection with specific models just alex Vizard 1 02-06-2009 11:02 AM
Collision with child nodes rubberpimple Vizard 4 09-17-2008 04:27 PM
collision with physics enabled joeymax Vizard 2 04-17-2008 02:49 PM
Collision detection with haptic pen mjabon Vizard 3 01-17-2008 06:35 PM
collision events trigger Eunice Vizard 1 01-03-2006 10:39 AM
