Old 02-05-2009, 01:11 PM
Here are two options. For your code without the group node you could replace
vizact.onkeydown(' ',bar2.visible,viz.TOGGLE)
with something like
vizact.onkeydown('1',bar2.disable,viz.RENDERING)
vizact.onkeydown('2',bar2.enable,viz.RENDERING)
the third bar will continue to be rendered whether or not the second one is
in the code with group node and the link you could add
link.setSrcFlag(viz.ABS_GLOBAL)
after creating the link. The third bar will be in the correct position and you can toggle the visibility of the second bar.
Old 02-10-2009, 06:20 AM
Sandro Holzer Sandro Holzer is offline
Thank you Jeff
The version with "bar.disable,viz.RENDERING" works best for me, and I think this is the easiest way to do it.
And with this version I can still use the "box.visible,viz.TOGGLE" command when I want all linked nodes to disappear.
Sandro
Vertex shader performance problem Joran Vizard 2 11-17-2008 01:29 AM
export problem bazelaisr Vizard 2 05-28-2008 10:19 AM
5DT Data Glove 5 Ultra Problem bjgold Vizard 1 08-08-2006 04:08 PM
PROBLEM: Picture-in-Picture breaks textures?!? vcarlson Vizard 4 10-05-2004 04:22 PM
