Old 09-19-2018, 04:10 AM
The following code works for me. The appearance of the cylinder parts do not change when the ground is faded. I had an issue with the alpha that was fixed after updating my nvidia graphics drivers.
import viz, vizshape, vizact
import random
viz.setMultiSample(4)
world = viz.addChild('ground.osgb')
light = viz.addLight()
light.setEuler(0,45,0)
# create spot
spot_elevation = .05
spot_height = 2.5
spot_nslices = 4	#originally 100
spot_slice_height = spot_height / spot_nslices
alpha_start = 0.5
alpha_end = 0.0
alpha_step = (alpha_end - alpha_start)/spot_nslices
print alpha_step
spot = []
for a in range(spot_nslices):
	cyl = vizshape.addCylinder(height=spot_slice_height, radius=0.30, color=viz.YELLOW, top=None)
	print a*alpha_step
	cyl.alpha( alpha_start + a*alpha_step )
	cyl.enable(viz.SAMPLE_ALPHA_TO_COVERAGE)
	cyl.disable(viz.BLEND)
	spot_yPos = spot_slice_height/2 + spot_elevation + a*spot_slice_height
	cyl.setPosition([0,spot_yPos,10])
	spot.append(cyl)
# rotate ground
def random_rotate(object_to_rotate, duration):
        rotate_val = random.randint(1, 360)
        spinto = vizact.spinTo(euler=(rotate_val, 0, 0), time=0, mode=viz.REL_GLOBAL)
        fadeout = vizact.fadeTo(0, time=duration)
        fadein = vizact.fadeTo(1, time=duration)
        rotate_action = vizact.sequence(fadeout, spinto, fadein)
        object_to_rotate.addAction(rotate_action)
vizact.onkeydown('r', random_rotate, world, 1)
import vizcam
cam = vizcam.PivotNavigate(center=[0,0,10],distance = 7)
cam.rotateUp(30)
cylinder, gradient, transparency
maintaining transparency in a model while fading in krimble Vizard 3 08-17-2017 07:10 AM
transparency control hankiwan Vizard 1 02-14-2012 08:02 AM
How to vary the transparency of the scene whj Vizard 2 04-04-2010 09:16 PM
How to vary the transparency of part of the scene whj Vizard 0 04-02-2010 03:32 PM
Quicktime movie with transparency channel aaThomas Vizard 7 11-12-2007 10:54 AM
