Old 03-17-2016, 06:38 AM
It will be easier to use vizconnect for the setup. You can also use the same vizconnect file with the demo launcher and any of your own Vizard applications. Attached is a file you can try out. First run the vizconnect file directly. You'll need to go to the transports tab and press the mapping button to choose which xbox signals drive the transport. There's a height offset added to the DK2 tracker. Remove this offset if you're using position tracking. Once the config file works on it's own you can import it into other scripts.
Turn using keyboard when using Oculus Seadna Vizard 9 01-12-2016 11:54 PM
Oculus setZoom mshukun Vizard 3 10-24-2014 09:04 AM
