Old 10-08-2014, 11:23 AM
mshukun mshukun is offline
Oculus setZoom
It appears that there are more Oculus related modules in Vizard 5 and I truly appreciate newly added functions. However, I encountered a problem that not to be able to zoom in and out using Xbox controller. It was working with the Vizard 5 beta version, but the code no longer work with the Vizard 5 (the code shown below). I appreciate your help and thank you in advance.
self.zoom = 1
def setZoom(self):
		if joy.isButtonDown(6):
			self.zoom = self.zoom - 0.001
		elif joy.isButtonDown(5):
			self.zoom = self.zoom + 0.001
		hmd.setZoom(self.zoom)
vizact.ontimer(0, self.setZoom)
Old 10-08-2014, 01:05 PM
Can you narrow down the problem to either the joystick code or the zoom command? Does the zoom command work for you on its own?
import oculus
hmd = oculus.Rift()
hmd.setZoom(1.5)
Old 10-20-2014, 10:57 AM
I found that setZoom is not working... How can I fix the problem? I have Oculus DK1.
Old 10-24-2014, 08:04 AM
I would very much appreciate any of your inputs regarding the Oculus setZoom function. I tested <hmd>.setZoom() for both 360 panorama and the 'piazza.osgb', but I wasn't able to make the function work. I didn't have any problems with Oculus setZoom() using Vizard 4 and Vizard 5 Beta so I am wondering if I need to do something extra or different approach for Vizard 5.
Thank you in advance.
import oculus
viz.setMultiSample(4)
viz.fov(60)
viz.go(viz.FULLSCREEN)
hmd = oculus.Rift()
# I tested various numbers for hmd.setZoom(), but it is not working...
hmd.setZoom = (1.5)
env = viz.addEnvironmentMap('C:/Program Files/WorldViz/Vizard5/resources/townhall_L.jpg')
sky = viz.addCustomNode('skydome.dlc')
sky.texture(env)
Problem with navigation trough DK2 Oculus vantsal Vizard 2 12-11-2014 03:18 AM
Oculus DK1 and DK2 in Vizard 5 Jeff Vizard 3 10-02-2014 11:00 AM
Oculus Rift Fullscreen teklab Vizard 6 05-21-2014 06:11 AM
oculus rift and inertia cube interaction problems apboone Vizard 4 03-13-2014 10:45 AM
Html and vizlink on Oculus HMD mshukun Vizard 3 10-30-2013 09:56 AM
