Old 02-19-2016, 09:31 AM
Open the model in Inspector and in the view pane highlight the part of the model that will move up and down. Find the corresponding node that's highlighted in the scenegraph tree. Right click on that node and select 'insert above' and then 'transform' and give the transform a name. Go to File > Save As to save a new version of the model with the transform node in the scengraph. See the hierarchical models page for example code to get a handle to a transform node in the script. You can move the floor up and down by moving the transform node.
Old 02-19-2016, 07:11 PM
RECVEB_RA RECVEB_RA is offline
Hi Jeff,
Thanks, I managed to specify the pit area. However, whenever I press to lower it this happens (see attached picture). I have been trying to find in the code something indicative of the final lowering point but am unable to find it. Any advice?
Old 02-21-2016, 02:06 AM
The floor's local coordinate system does not match Vizard's. You can highlight the floor in Inspector and activate translation to see how it's axes are oriented. The following code works to drop/raise the floor:
room = viz.addChild('room.osgb')
floor = room.getTransform('floor')
def dropFloor():
	floor.setPosition([0,0,0.4],viz.REL_LOCAL)
def raiseFloor():
	floor.setPosition([0,0,-0.4],viz.REL_LOCAL)
vizact.onkeydown('1', dropFloor)
vizact.onkeydown('2', raiseFloor)
EXE creating a new folder mshukun Vizard 2 09-23-2014 07:40 AM
Walk roobert Vizard 6 08-19-2014 08:07 PM
Creating a new DLS in trial license jmay Plug-in development 3 04-30-2014 10:30 AM
Creating Realistic Turns in Vizard using walkTo mikeb Vizard 1 02-28-2014 06:51 AM
random walk in piazza environment maya Vizard 7 01-15-2014 05:58 AM
