Old 11-18-2015, 08:56 AM
Qiliang He Qiliang He is offline
Yield until joystick is deflected by a certain degree
I've read the example scripts of yield statement, but I don't know how to realize this function: The function won't go to the next line until the user deflected the joystick beyond a certain degree. Here's my code:
HTML Code:
def pointing_task(joystick)
      some codes
      return angle,result  ##result is false means the joystick isn't deflected  beyond a certain threshold
def start_pointing():
      angle,result = pointing_task(joystick)
      yield result == True ??
      some codes
viztask.schedule(start_pointing())
My question is, how to use the yield statement to pause the program until a user deflect the joystick beyond a certain degree (result == True) and if he/she does, execute the following codes.
Thanks a lot!
Old 11-18-2015, 09:54 AM
lklab lklab is offline
have the pointing_task method be a loop that constantly is checking for joystick position. waits a few ms, then checks again.
something like
while( joystick position is not facing the right way)
yield viz.waittime(.01) #i forget the method
This way the loop will keep going and only exit until and continue with the rest of the program when the joystick is in position. the yield statement in the method makes other yield statement calling it actually wait and pause the program. (dont know why vizard does it this way but thats just how it is)
Old 11-18-2015, 10:28 AM
Thanks a lot!
joystick, yield
Yield until joystick is deflected by a certain degree Qiliang He Vizard 1 11-18-2015 09:41 AM
Unexpected Avatar lookAt() behavior when using yield statements chris2307 Vizard 2 12-17-2013 02:58 AM
Changing Joystick navigation halfway through kmkm Vizard 1 07-01-2013 07:02 PM
joystick position nmohandes Vizard 2 01-16-2012 10:03 AM
Facetracking and Immersion Joystick Vygreif Vizard 1 01-25-2006 10:56 AM
