Old 11-18-2015, 08:15 AM
Qiliang He Qiliang He is offline
Yield until joystick is deflected by a certain degree
I've read the example scripts of yield statement, but I don't know how to realize this function: The function won't go to the next line until the user deflected the joystick beyond a certain degree. Here's my code:
HTML Code:
def pointing_task(joystick)
      some codes
      return angle,result  ##result is false means the joystick isn't deflected  beyond a certain threshold
def start_pointing():
      angle,result = pointing_task(joystick)
      yield result == True ??
      some codes
viztask.schedule(start_pointing())
My question is, how to use the yield statement to pause the program until a user deflect the joystick beyond a certain degree and if he/she does, execute the following codes.
Thanks a lot!
Old 11-18-2015, 09:41 AM
I got it. viztask.waitTrue() can do the job.
joystick, yield
Unexpected Avatar lookAt() behavior when using yield statements chris2307 Vizard 2 12-17-2013 02:58 AM
Changing Joystick navigation halfway through kmkm Vizard 1 07-01-2013 07:02 PM
joystick position nmohandes Vizard 2 01-16-2012 10:03 AM
exiting a yield statement starbug Vizard 2 01-12-2010 03:16 PM
Facetracking and Immersion Joystick Vygreif Vizard 1 01-25-2006 10:56 AM
