Old 06-29-2011, 02:30 PM
Wehrdo Wehrdo is offline
Normal Map Light
I have been trying to use normal maps in Vizard with the command
object.bumpmap(imagefile)
When I do this, the object becomes normal mapped, but light no longer affects it. For example, when running the following code, the cube is fully lit, but if I leave out the last line, the cube is dark like it should be.
import vizcam
viz.cam.setHandler(vizcam.PivotNavigate())
cube = viz.add("bump_test.dae")
norm_map = viz.add("bump.jpg")
cube.bumpmap(norm_map)
The same goes for adding lights. They do not light the normal mapped object. I have attached the files referenced in the above code.
Is this a bug, or is there something I'm doing wrong? Thanks for you help!
Old 07-06-2011, 07:45 AM
Do I need to explain the problem better, or is everybody just as stumped as I am?
bump map, bumpmap, normal map
Ambient light Enlil Vizard 0 05-03-2011 09:48 AM
V-Realm Builder background and light load problems mizutani_jun Vizard 0 10-08-2010 01:46 AM
Normal Map Workflow for Vizard shivanangel Vizard 2 03-10-2009 07:54 PM
Light parents in funny scenes Gladsomebeast Vizard 1 12-17-2008 12:38 PM
