Old 10-08-2010, 12:46 AM
mizutani_jun mizutani_jun is offline
Unhappy V-Realm Builder background and light load problems
I try to use simple background from V-Realm Builder in vizard but when i add this file as background.wrl file nothing appear in vizard window.
I know vizard already have skydome.dlc file to load sky easily but for now i just want simple file from V-Realm Builder.
I previously use matlab so i just want to make same sample to use in vizard.
I just use simple command like below but nothing appears but also no error found.
background=viz.add('wrl_files/background.WRL')
I try same command but for skydome like below.I dont add jpg sky files so nothing appears but at least i can see the background but this didnt happen when i load simple background file from V-Realm Builder.
skydome=viz.add('skydome.dlc')
I also try to add light function but also nothing appears.The command is like below.
light=viz.add('wrl_files/light.WRL')
I also add my files in zip file below.
Am i missing something?
Really need helps.
Thanks.
File Type: zip background.zip (389 Bytes, 3522 views)
File Type: zip light.zip (475 Bytes, 3458 views)
