Hi Roobert,
Thanks for your helpful reply. I tried the settings you gave which illuminated the ceiling nicely. I also wanted to illuminate the walls so I didn't disable the headlight which worked ok however even the default (maximum?) light 'spread' of 180 didn't illuminate the side walls very much so I also tried adding individual light sources to illuminate each wall (and disabled the headlight) I was a bit confused at the beginning with the position/euler settings for these directional lights - this is what I ended up with: euler=(0,0,0) for all lights position = (1,0,0,); (-1,0,0,0); (0,0,1,0), (0,0,-1,0) ... for the 4 separate lights. (set color & ambient for each too, as desired) cheers, John |
Tags |
lighting vizard osgb |
quick way to center a room at 0,0 ? | johnallen | Vizard | 2 | 06-11-2014 06:38 AM |
Dark room illuminated by flashlight? | performlabrit | Vizard | 2 | 04-11-2014 10:29 AM |
room tilting when moving head up and down with HMD Nvis SX111 | karinp | Vizard | 7 | 01-24-2012 03:01 AM |
i want to ccreate a room for a virtual reality applications | nasruddin | Vizard | 1 | 03-20-2009 09:55 AM |
animating people wandering in a room | dellatails | Vizard | 5 | 02-13-2006 01:02 PM |
