Old 03-17-2014, 07:11 AM
Dark room illuminated by flashlight?
I'm having some strange issues with lighting.
My goal is to create a perfectly dark room that can be illuminated with a directional spotlight / flashlight.
However, I'm unable to get started, because I can't turn off lighting in the room! The room is empty, and consists of only 6 textured walls (this includes the ceiling and floor). I've set both the ambient and emissive properties of each wall to [0,0,0]. Yes, the headlamp has been deactivated, and no, I am not creating any other light sources. The walls still appear uniformly illuminated. What am I missing?
The next step will be to make sure that the planes are tesselated enough to produce smooth shading until spot illumination. Is jumping into Maya / 3Ds Max the best way to do this? Is there a clever way to subdivide planes in the code?
Thanks.
Old 03-18-2014, 12:17 AM
Does the following line of code help to darken the room?
room.appearance(viz.MODULATE)
Old 04-11-2014, 10:29 AM
Ah, rookie mistake here. Viz.lighting was off.
room tilting when moving head up and down with HMD Nvis SX111 karinp Vizard 7 01-24-2012 03:01 AM
i want to ccreate a room for a virtual reality applications nasruddin Vizard 1 03-20-2009 09:55 AM
animating people wandering in a room dellatails Vizard 5 02-13-2006 01:02 PM
