Old 06-24-2013, 11:31 AM
escmo escmo is offline
Exclamation Problems with linking Sensor to MainView
Dear community,
I have problems linking a tracker to the MainView. I'm trying two approaches, none of them is working right now. I'm using a Nvisor SX 60 HMD with InertiaCube 2+ sensor.
The first approach is using a viztracker, extract from vizsetupcfg.py:
isense = viz.add('intersense.dle')
headori = isense.addTracker(port=10)
viz.link(headori, viz.MainView)
and simply a 'viztracker.go()' after importing viztracker. The sensor works as wanted, but the MainView is rooted in (0,2,0) which is not where I want it to be, and setting the position of MainView has no effect.
The second approach is updating the Euler of MainView manually without linking, in which case I can set the position of MainView as usual but the sensor keeps spinning around the z-axis without sensor movement.
Is there any solution to either of the two approaches?
Thanks very much in advance!
Mainview can't go back to original point jacky Vizard 1 06-04-2013 05:22 AM
3ds Exported .IVE Model mirrors movement of Mainview Felix Vizard 9 05-18-2012 10:17 AM
IS-900 Wand linking Problems Kaminski Vizard 3 05-17-2011 10:39 AM
Link MainView to instable platform sleiN13 Vizard 2 01-10-2011 01:33 AM
Linking problems with Live Character Frank Verberne Vizard 5 06-04-2008 12:42 PM
