Old 05-16-2011, 01:33 PM
Kaminski Kaminski is offline
IS-900 Wand linking Problems
Hi All,
I am having trouble trying to link my IS-900 wand to a 3d node. When I print the orientation data from the wand it seems normal, but when I have a shape linked to the tracker the pitch, yaw, and roll seem to be reversed and not centered properly. Here is some example code:
cylinder = vizshape.addCylinder()
cylinder.color( viz.RED)
isense = viz.add('intersense.dle')
tr1 = isense.addTracker( port=4, station=1 )
tr2 = isense.addTracker( port=4, station=2 )
main = viz.link(tr1,viz.MainView)
cyl = viz.link(tr2,cylinder)
def printPos():
    print "cylPos ",cyl.getPosition()
    print "cylEul ",cyl.getEuler()
vizact.onkeydown( 'p' , printPos)
I have tried putting 'cylinder.center(tr2.getPosition()) before I link them. I have tried 'cyl.swapEuler' a few different ways but nothing seems right. I don't understand how the output euler can seem correct but the node could be way off. Any ideas?
Old 05-16-2011, 03:56 PM
Does it look fine when you link the viewpoint to the tracker?
Old 05-17-2011, 08:05 AM
Yes, linking the wand to the viewpoint results in normal viewpoint control.
Old 05-17-2011, 09:39 AM
I fixed it in the process of simplifying my code. I wish I could say how -- thanks anyway.
Problems loading WRL file DrunkenBrit Vizard 2 01-29-2009 12:58 AM
Export/import problems and Vizard 3.0 release searsky Vizard 0 01-03-2006 01:34 AM
Problems Importing VRML Files oscar Vizard 4 10-13-2004 05:42 PM
Problems with lighting in 2.0 murm Vizard 6 04-21-2004 09:59 AM
