Old 01-04-2011, 07:49 AM
sleiN13 sleiN13 is offline
Link MainView to instable platform
I've got a moving platform that can raise, roll, pitch, turn and move forward. To this platform I want to link the MainView. Besides being linked to the platform the MainView also has to be linked to a joystick/keyboard controls and in the future a HMD 6-dov tracker.
I solved this problem by creating a function that is called every frame and that combines a fixed point on the platform (VizGroup) with a user (VizGroup) object. The user object is moved by the joystick/keyboard while the platform is moved by VizActions.
def setView(event):
        matLoc = plane.getMatrix(viz.ABS_GLOBAL)
        matUser = user.getMatrix()
        matFinal = vizmat.Transform()
        matFinal.preMult(matLoc)
        matFinal.preMult(matUser)
        viz.MainView.setMatrix(matFinal)
viz.callback(viz.UPDATE_EVENT, setView)
This all seems to work fine until you do a roll with the platform while it is moving forward. After +/- 30 seconds the image starts to shake, this continues while in a roll but disappears when the roll is set back to 0 again.
I've included a example script with a distilled version of my code. As soon as you initiate a roll (using the slider) the image will get shake very slightly but as soon as you move a small amount forward (w key) the shaking gets extreme. The shaking is always the most noticeable if you move close to objects on the platform.
My question is: How to link a controllable MainView to a instable platform that does not create a shaking image.
Old 01-08-2011, 06:26 PM
Does it make any difference if you use the postMultLinkable operator instead of a group node?
link = viz.link(tracker,viz.MainView)
link.postMultLinkable(platform)
This should link the view to whatever tracker you use but keep it in the reference frame of the platform.
Old 01-10-2011, 01:33 AM
The result of using
are the same. Still the image is shaking and getting worse over time.
link MainView moneim230 Vizard 1 09-14-2010 02:47 PM
Remove link and have object drop/collide? cgibb Vizard 6 03-02-2010 05:18 PM
Can you link the position of a tracker to the orientation of an object? michaelrepucci Vizard 1 09-19-2008 11:23 AM
How to make a link Sabina Volcy Vizard 1 02-12-2008 11:43 AM
