Old 09-30-2009, 03:20 PM
JimC JimC is offline
Unhappy Collision detection with custom nodes?
When I add:
viz.MainView.collision(viz.ON)
to the end of testCustomNode.py (example script from the plugin API), I can still drive the viewpoint right through the middle of the polygon. What am I missing?
-Jim
Old 10-02-2009, 11:54 AM
Is your custom node using raw OpenGL command to render? If so, then collisions won't work because OpenSceneGraph will not know anything about the mesh of your object. There are two ways to handle this:
1) Use the built-in osg::Geometry class to render your object
2) Implement the following osg::Drawable methods in your custom drawable class:
virtual bool supports(osg::PrimitiveFunctor&) const;
virtual void accept(osg::PrimitiveFunctor& pf) const;
These methods allow you to pass information about your mesh to OpenSceneGraph, which will allow it to participate in collision/intersection/pick tests. Here is a very simple example showing how to implement this for a simple quad:
virtual bool supports(osg::PrimitiveFunctor&) const { return true; }
    pf.begin(GL_QUADS);
    pf.vertex(-1,1,0);
    pf.vertex(1,1,0);
    pf.vertex(1,-1,0);
    pf.vertex(-1,-1,0);
    pf.end()
Old 10-02-2009, 12:49 PM
This is just the custom-node example plugin that comes with the plugin API. It draw a single (deforming) square.
I assumed that the Drawable's computeBound() method, which returns a BoundingBox, was used for collision detection. The overridden computeBound() method in the example plugin appears to be returning reasonable values, and it does get called by winviz. If not for collision detection, what is this method for?
-Jim
Old 10-02-2009, 01:01 PM
Culling?
-Jim
Old 10-02-2009, 01:24 PM
The bounding box of the drawable is used for culling.
Collision detection with specific models just alex Vizard 1 02-06-2009 12:02 PM
Collision Detection and Nearest Point to Probe xabbu Vizard 2 01-06-2009 04:01 AM
Collision with child nodes rubberpimple Vizard 4 09-17-2008 05:27 PM
Collision detection with haptic pen mjabon Vizard 3 01-17-2008 07:35 PM
Walking avatars --> collision detection? sjroorda Vizard 3 10-13-2005 05:47 AM
