Old 05-15-2009, 10:45 PM
gwfassociates gwfassociates is offline
Exclamation Immersion Cyberglove connection problem
The immersion cyberglove works fine in the Immersion DCU program I run the Device manager and the glove works. But when I run the immersion cyberglove demo in vizard 3.0 I get an error:
Failed to connect to CyberGlove. Make sure Device Manager is running. could not connect to device.
The device manager is running. The vizard loads CyberGlove driver v1.0.
I have it running on one computer fine so the hardware all works (its a win xp SP3).
I'm testing on windows XP no service pack could that cause problems?
Old 05-17-2009, 04:29 PM
Does the broken computer have a "virtual hand" license? I think there is a 30 day trial period after installing the Cyberglove software, after which you need to license it to connect in Vizard.
You other computer probably has a valid license.
Paul Elliott
WorldViz LLC
Vertex shader performance problem Joran Vizard 2 11-17-2008 02:29 AM
export problem bazelaisr Vizard 2 05-28-2008 11:19 AM
Facetracking and Immersion Joystick Vygreif Vizard 1 01-25-2006 11:56 AM
sound problem alaa Vizard 7 09-02-2005 02:13 PM
