Old 04-05-2015, 10:08 AM
sportykourty sportykourty is offline
Question Error Changing Scenes
I'm trying to have my program change scenes once I enter a proximity sensor. I keep receiving an error. Any ideas what i'm doing wrong?
import vizproximity
viz.setMultiSample(4)
############# Movement Control Code###################
#Script to control viewpoint with keyboard arrow keys
MOVE_SPEED = 900
TURN_SPEED = 60
def updatecar():
	#move view forward and backward
	if viz.key.isDown(viz.KEY_UP):
			view.move([MOVE_SPEED*viz.elapsed(),0,0],viz.BODY_ORI)
	if viz.key.isDown(viz.KEY_DOWN):
			view.move([-MOVE_SPEED*viz.elapsed(),0,0],viz.BODY_ORI)
	if viz.key.isDown(viz.KEY_TAB):
			view.move([0,MOVE_SPEED*viz.elapsed(),0],viz.BODY_ORI)
	if viz.key.isDown(viz.KEY_SHIFT_L):
			view.move([0,-MOVE_SPEED*viz.elapsed(),0],viz.BODY_ORI)
	#rotate body of view left and right
	if viz.key.isDown(viz.KEY_RIGHT):
			view.setEuler([TURN_SPEED*viz.elapsed(),0,0],viz.BODY_ORI,viz.REL_PARENT)
	elif viz.key.isDown(viz.KEY_LEFT):
			view.setEuler([-TURN_SPEED*viz.elapsed(),0,0],viz.BODY_ORI,viz.REL_PARENT)
vizact.ontimer(0,updatecar)
########### Viewpoint Code #################
#Start collision detection
viz.MainView.collision( viz.ON )
view = viz.MainView
#Get rid of gravity.
viz.MainView.gravity(0)
#Set the viewpoint.
viz.MainView.setPosition(88,0,-443)
#Viewpoint
view = viz.MainView
#Actual Viewpoint
view.setPosition([-7034, 200, -10775])
view.setEuler([90, 0, 0])
mars = viz.add('gallery.osgb',scene = viz.Scene1)
viz.addChild('dojo.osgb',scene=viz.Scene2)
manager.setDebug(True)
manager.addTarget( vizproximity.Target(viz.MainView) )
# Create sensor using bounding box of node
node = viz.addChild('plant.osgb',pos=(-4034, 0, -10775),scale=(1000,1000,1000))
node.addAction(vizact.spin(0,1,0,45,viz.FOREVER))
sensor = vizproximity.addBoundingBoxSensor(node)
manager.addSensor(sensor)
def changeScene(scene):
	viz.MainWindow.setScene(scene)
	if scene == viz.Scene2:
		viz.MainView.setPosition([0,1.8,0])
		viz.MainView.setEuler([90,0,0])
manager.onEnter(None, changeScene)
Old 04-08-2015, 07:03 AM
mape2k mape2k is offline
The problems you have originate from the last bits of your code:
In the last line, you tell Vizard to call the function changeScene() whenever the sensor is entered. The argument that gets passed to that function by default is the sensor that was activated. So your variable <scene> will be a proximity sensor => this will create an error when trying to change the scene to a sensor.
To fix this, you need to pass more arguments to the function changeScene, e.g.:
def changeScene(sensor,scene):
manager.onEnter(None, changeScene, desiredScene)
in which <desiredScene> is the variable to the scene you wish to change to.
Adding Objects to all Scenes jassel41 Vizard 1 11-29-2010 03:35 AM
displaying random scenes etc cl113 Vizard 1 05-10-2009 06:14 PM
Making buttons appear in scenes DBurks2818 Vizard 4 04-09-2009 03:25 PM
Arranging Scenes in Correct Order utepbereed Vizard 1 11-21-2008 10:19 AM
environment maps, scenes, and you! vadrian Vizard 1 01-12-2005 05:04 PM
