Old 05-14-2013, 01:37 AM
mape2k mape2k is offline
Draw distance
is there any way to change the draw distance of the rendering engine? I am using a very large scene and the ground looks very washed out around the viewport. I would like the textures to be rendered in more detail for a longer distance from the viewport.
Thanks!
Old 05-14-2013, 07:56 AM
It sounds like you need to enable anisotropic filtering on the ground texture. For example, try the following command on your ground model or texture:
ground.anisotropy(4)
This should make the texture appear more sharp when viewing at sharp angles.
Problem Vizdlg panel draw order Chapre Vizard 1 05-17-2011 02:29 PM
Camera distance problem CRI Vizard 0 07-28-2010 10:58 AM
Draw line with a triangle at the end Chrissy2009 Vizard 9 08-24-2009 11:12 AM
Draw a triangle instead of a point Chrissy2009 Vizard 1 07-21-2009 09:46 AM
Draw Vector in viewpoint lookat direction Chrissy2009 Vizard 2 05-30-2009 12:50 AM
