Old 05-17-2011, 04:36 AM
Chapre Chapre is offline
Problem Vizdlg panel draw order
How do I draw a vizdlg panel behind other 2D object (texture quad, button) not belonging to the panel , since setting the draw order to a very low value doesn't solve the problem.
Old 05-17-2011, 02:29 PM
Add the 2D object to the ortho layer, that's what panels are added to. Then you can set the draw order:
import vizdlg
myPanel = vizdlg.Panel(align=vizdlg.ALIGN_CENTER)
myPanel.addItem(viz.addText('A simple panel'),align=vizdlg.ALIGN_CENTER)
myPanel.addItem(viz.addCheckbox())
myPanel.addItem(viz.addSlider())
myPanel.addItem(viz.addTextbox())
viz.link(viz.CenterCenter,myPanel)
quad = viz.addTexQuad(parent=viz.ORTHO)
quad.texture(viz.addTexture('image2.jpg'))
quad.drawOrder(5)
quad.setScale([200]*3)
viz.link(viz.CenterCenter,quad)
slider = viz.addSlider()
slider.set(1)
slider.setPosition([0.5,0.2,0])
def alphaSlider(pos):
	quad.alpha(pos)
vizact.onslider(slider,alphaSlider)
one panel over all windows Andy Vizard 5 04-11-2012 09:24 AM
vizdlg Panel: Add and remove disbeat Vizard 2 02-08-2011 12:44 PM
vizdlg dialog components on a single panel Chapre Vizard 3 11-20-2010 02:47 PM
