Old 11-29-2010, 12:47 PM
flip321 flip321 is offline
Question Moving objects smoothly
Hey,
does anyone know how to make a movement of an object smooth? I mean that the acceleration and breaking process is smooth and gives it a more realistic feeling?
Thanks a lot
flip321
Old 12-01-2010, 09:29 AM
Can you provide more detail about what you are trying to do?
Old 12-08-2010, 05:29 AM
Of course:
Let's say I want to move an imported 3D-object from it's position to the center of the stage/screen whatever with the coordinates [0,0,0]. The skript works, but in order to make it look more realistic in a physical way, I want the beginning of the movement progress to start slower as well as the ending of the movement.
In other words I want the speed of the movement to increase in the beginning and decrease in the end, and NOT to have a constant movement speed over the whole time.
Here's a part of the script I'm using right now:
def show_moviepreviews():
moveToStage = vizact.moveTo([0, 0, 0],time=1)
movie_icon.addAction(moveToStage)
Thanks a lot,
Philipp
Old 12-09-2010, 12:32 AM
Huib Huib is offline
If you have some t, going linearly from 0.0 to 1.0, first transform it before passing it to setPosition or whatever move function.
Example for slow in, slow out:
new_t = (1.0 - math.cos(math.pi * t)) * 0.5
bonus for fast in, slow out:
new_t = math.sin(((1.0 - t) ** 2 + 1) * math.pi / 2.0) ** 2
these new_t values will lie between 0.0 and 1.0 as well.
Old 02-24-2011, 03:45 AM
hm, could you add this into my example skript? I can't really picture who I should integrate it...
Isn't there any easier way like giving an extra parameter along with the "move function" in order to get the same results?
But thanks a lot in advance!!! I appreciate it!
Old 12-21-2011, 02:01 AM
Better approach: see the help for interpolation modes, for instance:
    moveToStage = vizact.moveTo([0, 0, 0], time=1, interpolate=vizact.easeInOut)
Moving objects together imperialkat Vizard 2 02-17-2010 12:43 PM
Moving multiple objects with ppt durf Vizard 1 02-10-2009 03:03 PM
