Old 07-14-2010, 12:35 PM
llqqff llqqff is offline
winviz.exe problem
Hi, I am using Vizard 3.0 with wireless cyberglove 2. But there was a running problem with my code, my code is as below:
import hand
sensor = viz.add('cyberglove.dls')
glove = hand.add(sensor,hand.CYBERGLOVE)
When I run it, it shows a dialog:
Winviz.exe has encountered a problem and needs to close.
When I click the error report, it shows:
Error signature
AppName: winviz.exe AppVer: 0.0.0.0 ModName: virtualhandregistry.dll
ModVer: 0.0.0.0 Offset: 000018a0
Is there anyway to solve this problem.
Thanks.
Old 07-15-2010, 05:36 PM
Make sure the hand is animated in Immersion's DCU before running Vizard. Do you then have any trouble with the following:
immersion = viz.add('immersion.dle')
glove = immersion.addCyberGlove()
data = glove.getData()
Old 07-16-2010, 10:08 AM
The DCU is running. And when I use the
It still crashed and show the same problem. It seems to me that the problem is importing the cyberglove or immersion plugin problem. I tried to use the 5dt.dls, it does not crashed.
Vertex shader performance problem Joran Vizard 2 11-17-2008 02:29 AM
export problem bazelaisr Vizard 2 05-28-2008 11:19 AM
problem with female animations vmonkey Vizard 1 10-07-2005 11:36 AM
sound problem alaa Vizard 7 09-02-2005 02:13 PM
PROBLEM: Picture-in-Picture breaks textures?!? vcarlson Vizard 4 10-05-2004 05:22 PM
