Create an arc between two points
I have two x, z points - for example ([1.722, .46], [3.94, .026]) - and I am trying to draw an arc (or a great (or small) circle) between the two points. I also have calculated 50 control x, z points between the points if this is beneficial to the solution.
Currently, I am using viz.LINE_STRIP to create about 50 line segments between the two points and it doesn't look at all. Any help would be great and please let me know if more information is needed. Thanks, Chris |
What exactly is wrong with your current solution? Is the arc not smooth enough? If so, you will just need to create more control points.
I am not calculating the y-values correctly. When drawn, it looks like a staircase between the two points.
Can you post some sample code?
So I transferred some Matlab code into Python and then did a 3D plot, see below code.
import numpy as np from mpl_toolkits.mplot3d import Axes3D import matplotlib.pyplot as plt def get_sphere_line(center, pt_1, pt_2): """ Get the coordinates to craft an arc """ x0, y0, z0 = center x1, y1, z1 = pt_1 x2, y2, z2 = pt_2 v1 = [x1 - x0, y1 - y0, z1 - z0] # Vector from center to 1st point r = np.linalg.norm(v1) # The radius v2 = [x2 - x0, y2 - y0, z2 - z0] # Vector from center to 2nd point v3 = np.cross(np.cross(v1, v2), v1) # v3 lies in plane of v1 & v2 and is orthog. to v1 v3 = r*v3/np.linalg.norm(v3) # Make v3 of length r # Let t range through the inner angle between v1 and v2 t = np.linspace(0, np.arctan2(np.linalg.norm(np.cross(v1, v2)), np.dot(v1, v2)), num=100)[:, np.newaxis].T v = np.array(v1)[:, np.newaxis]*np.cos(t) + np.array(v3)[:, np.newaxis]*np.sin(t) # v traces great circle path, relative to center xs, ys, zs = v[0, :] + x0, v[1, :] + y0, v[2, :] + z0 return xs, ys, zs xs, ys, zs = get_sphere_line([2.85, 0.001, 0.238], [1.722, .001, .46], [3.94, 0.001, 0.026]) fig = plt.figure() ax = fig.add_subplot(111, projection='3d') ax.plot(xs, ys, zs) plt.show() The below code is how I am trying to implement it in Vizard, but it isn't working properly. vs = get_sphere_line([2.85, 0.001, 0.238], [1.722, .001, .46], [3.94, .001, 0.026]) viz.startLayer(viz.LINE_STRIP) viz.lineWidth(5) viz.vertexColor(viz.YELLOW) for v in vs: viz.vertex([v[0], v[1], v[2]]) viz.endLayer() |
I found the problem, here is my solution in Vizard:
xs, ys, zs = get_sphere_line([2.85, -1., 0.238], [1.722, .001, .46], [3.94, .001, 0.026]) viz.startLayer(viz.LINE_STRIP) viz.lineWidth(5) viz.pointSize(5) viz.vertexColor(viz.YELLOW) for pos in zip(xs, ys, zs): viz.vertex([pos[0], pos[1], pos[2]]) points = viz.endLayer() |
| Tags |
| arc, great circle, vizshape |
| Thread Tools | |
| Why I need two points for viz.startlayer(viz.POINTS) | jincheker | Vizard | 1 | 01-28-2011 09:46 AM |
| avatar walking over a sequence of points | IGoudt | Vizard | 1 | 10-16-2009 12:22 PM |
| Create Button or Text | Chrissy2009 | Vizard | 1 | 07-15-2009 06:34 PM |
| Draw Line between Points | Chrissy2009 | Vizard | 2 | 05-13-2009 05:42 AM |
| How to create a sky? | guxmy01 | Vizard | 1 | 05-28-2008 01:07 PM |
