Old 05-27-2008, 03:28 AM
guxmy01 guxmy01 is offline
How to create a sky?
hello!
Im new to this Vizard software. My task is to create a VR of my building and its surrounding. The problem I faces are :
a) How to create a sky background using JPEG?
b)If i turn on the light, is it the shadow is automatically on?
Anyone can help me?
Old 05-28-2008, 01:07 PM
a) Vizard comes with a sample sky cubemap. You can use the following code to use it:
sky = viz.add(viz.ENVIRONMENT_MAP,'sky.jpg')
skybox = viz.add('skydome.dlc')
skybox.texture(sky)
There are many sample sky cubemaps available online as well. Just do a google search for them.
b) Light object do not cast shadows. If you need static shadows, then the best option is to bake the shadow into a lightmap using a tool like 3dsmax. If you need dynamic shadows, then search through the forum. There are a few sample scripts posted showing how to setup shadows in Vizard.
questions on how to create a form xingxing Vizard 15 06-13-2008 05:19 PM
Getting a mirror to work in any environment Frank Verberne Vizard 5 03-27-2008 09:21 AM
Create my own animations michelcm3 Vizard 1 09-21-2007 10:53 AM
how to create morph from the comple characters CD michelcm3 Vizard 9 07-19-2007 11:15 AM
SEOS HMD 120/67 compatability John Vizard 18 05-28-2004 12:13 PM
