Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 05-20-2013, 11:27 AM
jacky jacky is offline
Mainview can't go back to original point
Hi all,
I created two boxes. One box connected to the sensor with 3DOF orientation and the other one connected to the Mainview. I linked the two boxes with function viz.grab(). The mouse's buttons were used to make mainview forward or backward along the direction of mainview. The space key was used to make the boxes back to the original point with positions (0,0,0) and euler (0,0,0). But it did not work. I didn't the reason. If someone know, please tell me. Thanks very much.
key commands:
	r						- reset the position and orientation of mainview,
							  place the mainview at the original point
	mouse's left button	    - move the mainview forward
	mouse's right button	- move the mainview backward
	up array				- move the mainview forward
	down array			    - move the mainview backward
	4						- move the mainview forward
	1						- move the mainview backward
	5						- move the mainview up along the +Y axis( increase eyeheight)
	2						- move the mainview down along the -Y axis(decrease eyeheight)
import math
import vizinput
viz.setMultiSample(4)
eyeheight=1.65
viz.eyeheight(eyeheight)
#sensor_place=['Sensor facing FORWARD','Sensor facing LEFT']
#place=vizinput.choose('Select Sensor Config',sensor_place)
display_mode=['2D_Fullscreen','Sony Hmz-T1']
i = vizinput.choose('Select Display Mode', display_mode )
if i==0:
	viz.go(viz.FULLSCREEN)
	import sony
	hmd=sony.HMZT1()
#load the 3 space sensor information
import threespace_api as ts_api
device_list, unknown_list = ts_api.getAvailableComPorts()
for device_port in device_list:
	com_port, friendly_name, device_type=device_port
	if device_type=="USB":
		device=ts_api.TSSensor(com_port=com_port)
	elif device_type=='DNG':
		device=ts_api.TSDongle(com_port=com_port)
		#device=dng_device[0]
	elif device_type=='WL':
		device=ts_api.TSWLSensor(com_port=com_port)
#load the environment model
environment=viz.addChild('gallery.osgb')
#make mouse invisible and activate mainview's collision
viz.mouse.setVisible(viz.OFF)
viz.mouse.setOverride()
viz.MainView.collision(viz.ON)
viz.MainView.collisionBuffer(0.5)
#viz.MainView.gravity(0)
box_scale=0.0001
box_pos=[0,eyeheight,0] #box1 and box2 must be in the same position
box2_sensor=viz.addChild('crate.osgb') #link box2 to 3 space sensor
box2_sensor.setPosition(box_pos)
box2_sensor.setScale([box_scale]*3)
box1_view=viz.addChild('crate.osgb')
box1_view.setPosition(box_pos)
box1_view.setScale([box_scale]*3)
#link mainview to box1 in Vizard
link2=viz.link(box1_view,viz.MainView)
#link box1 to box2
link=viz.grab( box2_sensor, box1_view )
#reset the mainview to the original position
def reset_mainview():
    global link,link2
    link2.remove()
    link.remove()
    link=None
    link2=None
    pos=environment.getPosition()
    pos[1]=pos[1]+eyeheight
    euler=environment.getEuler()
    box1_view.setPosition(pos)
    box1_view.setEuler(euler)
    box2_sensor.setPosition(pos)
    #viz.MainView.setPosition(0,0,0)
    #viz.MainView.setEuler(0,0,0)
    link2=viz.link(box1_view,viz.MainView,srcFlag=viz.ABS_GLOBAL)
    link=viz.grab(box2_sensor,box1_view)
vizact.onkeydown(' ',reset_mainview)
degree=180/math.pi
#link the rotation of mainview to the 3 space sensor.
#def connect_USB_Forward():
#	sensor_euler=device.getFiltTaredOrientEuler() #[pitch,yaw,roll] in radians
#	yaw=sensor_euler[1]*degree
#	pitch=sensor_euler[0]*degree
#	roll=sensor_euler[2]*degree
#	box2_sensor.setEuler(yaw,-pitch,-roll)
#link the rotation of mainview to the 3 space sensor every frame
def connect():
	box2_sensor.setEuler(yaw,pitch,roll)
vizact.ontimer(0,connect)
#move the mainview along the view direction
param=0.02 # the step of increase or decrease distance
def move_forward():
	pos=viz.MainView.getPosition()
	yaw=viz.MainView.getEuler()[0]*(math.pi)/180
	#pos=box1_view.getPosition()
	#yaw=box1_view.getEuler()[0]*(math.pi)/180
	cos=math.cos(yaw)
	sin=math.sin(yaw)
	pos[2]=pos[2]+param*cos
	pos[0]=pos[0]+param*sin
	viz.MainView.setPosition(pos)
def move_backward():
	cos=math.cos(yaw)
	sin=math.sin(yaw)
	pos[2]=pos[2]-param*cos
	pos[0]=pos[0]-param*sin
#move the mainview along y axis
vizact.whilemousedown(viz.MOUSEBUTTON_LEFT,move_forward)
vizact.whilemousedown(viz.MOUSEBUTTON_RIGHT,move_backward)
vizact.onkeydown(viz.KEY_UP,move_forward)
vizact.onkeydown(viz.KEY_DOWN,move_backward)
vizact.onkeydown('4',move_forward)
vizact.onkeydown('1',move_backward)
If I changed the function move_forward() like below, It also didn't work and the mouse's button can't work either.
def move_forward():
	cos=math.cos(yaw)
	sin=math.sin(yaw)
Old 06-04-2013, 04:22 AM
As far as I can see, you commented out the two most important lines of reset_mainview(), namely:
Have you tried deleting the comments signs (#)?
3ds Exported .IVE Model mirrors movement of Mainview Felix Vizard 9 05-18-2012 09:17 AM
MainView and getEuler shivanangel Vizard 1 01-20-2012 10:31 AM
Link MainView to instable platform sleiN13 Vizard 2 01-10-2011 12:33 AM
data glove navigation arielasso Vizard 6 10-24-2007 02:15 PM
looking at a point vadrian Vizard 5 06-07-2005 05:43 PM
