Old 02-26-2013, 03:48 PM
pswaney pswaney is offline
Create a clipping box
I was wondering if it is possible to create a clipping box, such that an object inside the box would appear fully, but if the object was scaled such that any part of it fell outside the box, that portion would be clipped.
I have tried to use multiple clipping planes, but when creating the box, I am only able to create clipping planes on three sides of the box, and never two parallel sides. If, for example, I try to create two clipping planes that would form the top and bottom of the box, the plane I create second supersedes the first. See the example below for this behavior. Any help would be greatly appreciated, thanks!
import vizshape
vizshape.addGrid(color=[0.2]*3)
viz.clearcolor(viz.GRAY)
sphere = vizshape.addSphere(radius=3)
sphere.clipPlane([1,0,0,-1],num=1)
sphere.clipPlane([1,0,0,1],num=2)
import vizcam
vizcam.PivotNavigate(center=[0,2,0],distance=10)
Old 03-01-2013, 01:19 PM
It doesn't look like you are specifying the clip planes correctly. Here is a sample script that shows how to apply a clip box to the model:
import vizshape
model = viz.add('logo.ive')
expand = vizact.sizeTo([3,3,3],speed=0.5)
shrink = vizact.sizeTo([1,1,1],speed=0.5)
model.runAction(vizact.sequence(expand,shrink,viz.FOREVER))
model.runAction(vizact.spin(0,1,0,20,viz.FOREVER),pool=1)
def applyClipBox(node, center, size):
	x,y,z = center
	sx,sy,sz = [ v / 2.0 for v in size ]
	node.clipPlane([1,0,0,x-sx],num=0)
	node.clipPlane([-1,0,0,-x-sx],num=1)
	node.clipPlane([0,1,0,y-sy],num=2)
	node.clipPlane([0,-1,0,-y-sy],num=3)
	node.clipPlane([0,0,1,z-sz],num=4)
	node.clipPlane([0,0,-1,-z-sz],num=5)
BOX_CENTER = [0,2,0]
BOX_SIZE = [2,2,2]
applyClipBox(model,center=BOX_CENTER,size=BOX_SIZE)
box = vizshape.addBox(size=BOX_SIZE,pos=BOX_CENTER,color=viz.RED,lighting=False)
box.polyMode(viz.POLY_WIRE)
import vizcam
vizcam.PivotNavigate(center = BOX_CENTER, distance = 10.0)
Clipping Plane envisC Vizard 8 10-23-2012 01:36 PM
Can I make a moving clipping plane? Salvar Vizard 3 04-18-2012 01:32 PM
Near and far clipping on infinite terrain vijaykiran Vizard 2 01-21-2011 05:59 AM
Create Button or Text Chrissy2009 Vizard 1 07-15-2009 06:34 PM
How to create a sky? guxmy01 Vizard 1 05-28-2008 01:07 PM
