Old 03-24-2015, 08:21 PM
sportykourty sportykourty is offline
Question help with moving objects to different locations
Ok so I'm trying to have two different sized objects to randomly be in the hiding spot positions that I've put in my code. When i run the program the closet hiding spots work but I think the oxygen hiding spots are using the closet hiding spot coordinates so they are all wrong. can anyone help?
def MainTask():
	"""Top level task that controls the game"""
	# Display instructions and wait for key press to continue
	yield DisplayInstructionsTask()
	# List of hiding spots for pigeons
	CLOSET_HIDING_SPOTS = [
		 [-11832, 1250, -11706]
		,[-11001, 1250, -15297]
		,[-7000, 1250, -16800]
	OXYGEN_HIDING_SPOTS = [
		 [-5950,1650,-10700]
		,[-10000,1650,-16000]
		,[-10950,1650,-11500]
	# Create panel to display trial results
	resultPanel = vizinfo.InfoPanel('',align=viz.ALIGN_CENTER,fontSize=25,icon=False,key=None)
	resultPanel.visible(False)
	while True:
		# Randomly choose hiding spots from list
		locations1 = random.sample(CLOSET_HIDING_SPOTS,TRIAL_COUNT)
		locations2 = random.sample(OXYGEN_HIDING_SPOTS,TRIAL_COUNT)
		location1 = random.sample(locations1,TRIAL_COUNT)
		location2 = random.sample(locations2,TRIAL_COUNT)
		# Reset score
		score = 0
		UpdateScore(score)
		# Go through each position
		for pos in locations1:
			# Perform a trial
			found = yield TrialTask(pos)
			# Update score and display status text
			if found:
				#viz.playSound('sounds/pigeon_catch.wav')
				score += 1
				UpdateScore(score)
				resultPanel.setText(TRIAL_SUCCESS)
				#viz.playSound('sounds/pigeon_fly.wav')
				viztask.schedule(FadeToGrayTask())
				resultPanel.setText(TRIAL_FAIL)
			#Display success/failure message
			resultPanel.visible(True)
			# Add delay before starting next trial
			yield viztask.waitTime(TRIAL_DELAY)
			# Disable gray effect
			gray_effect.setEnabled(False)
		for pos in locations2:
			# Perform a trial
			if found:
				score += 1
				UpdateScore(score)
		#Display results and ask to quit or play again
		resultPanel.setText(RESULTS.format(score,2))
viztask.schedule( MainTask() )
Moving objects smoothly flip321 Vizard 5 12-21-2011 03:01 AM
Moving objects together imperialkat Vizard 2 02-17-2010 01:43 PM
Moving multiple objects with ppt durf Vizard 1 02-10-2009 04:03 PM
