Old 03-19-2013, 11:00 AM
mape2k mape2k is offline
Varying rotation speed with spinTo
I am using the spinTo command in a for loop to spin to different view angles during an experiment. I want the rotation speed to be constant, independent from the actual and desired view angle.
However, the spinTo command gives me different rotation speeds when I use it. Sometimes its faster, and sometimes its slower, even though I specify a constant speed angle.
I have attached a working minimum example. Here, the speed will vary, seemingly at random.
import viztask
angles = [-120,150,100,150,-170,50,90,150]
viz.addChild('piazza.osgb')
view=viz.MainView
def run():
	for k in angles:
		print str(k)
		yield viztask.addAction(view, vizact.spinTo(euler=[k,0,0],speed=80,interpolate = vizact.linear))
viztask.schedule(run())
Thank you for your help in advance!
Old 03-20-2013, 08:23 AM
This appears to be a bug with how the rotational differences are computed. It doesn't seem to be using the shortest distance in all cases. This will be fixed in the next release. In the meantime you can add the following code to the beginning of your script to get the correct behavior:
import math
import vizmat
def QuatDiff(q1,q2):
	w = abs((vizmat.Quat(q1) * vizmat.Quat(q2).inverse()).w)
	return viz.degrees(math.acos(w) * 2.0)
vizmat.QuatDiff = QuatDiff
Old 03-22-2013, 07:48 AM
Thank you for your quick reply and the hot-fix!
Custom Joystick Rotation mhead10 Vizard 9 11-26-2012 12:06 PM
random speed and associated coding Saz Vizard 1 05-20-2010 04:03 AM
set bone rotation - cal3d munteanu24d Vizard 0 03-23-2010 04:25 AM
Unable to perform 360 rotation using vizact.spinto vijaykiran Vizard 2 09-29-2009 08:39 AM
Calculating Speed with sensor durf Vizard 1 03-13-2009 10:25 AM
