Old 05-19-2010, 05:24 AM
Saz Saz is offline
random speed and associated coding
Hi there,
I want the code to sample a random accelerator gain from a predetermined list, but when the gain changes, the coding for the indicated speed in mph also has to change, to give the correct speed in the text box.
I put this together so far
#Import vizjoy module
import vizjoy
import time
import math
import vizinfo
import random
viz.displaymode(1024, 768)
viz.go(viz.FULLSCREEN)
viz.mouse(viz.OFF)
vizact.ontimer(40,viz.quit) #runs file for 40 secs
subject = viz.input('What is the participant number?')
MOVE_SPEED = 0.25 #initial speed scalar
#define random speed scalar constant for changing gain on accelerator
#Add a joystick
joy = vizjoy.add()
viz.clearcolor(0.5,0.5,1)
viz.MainView.setPosition(0,.5,0)
sky = viz.add(viz.ENVIRONMENT_MAP,'sky.jpg')
skybox = viz.add('skydome.dlc')
skybox.texture(sky)
#add the road texture
road = viz.add('roadld3.png')
#road2 = viz.add('roadsd.png')
#add the ground
ground.setPosition(0,0,25)
#create a texture quad to add the road texture to
#and place it over ground
quad = viz.addTexQuad()
quad.setScale(1,2,1)
quad.setPosition(0,.1,0)
quad.setEuler(0,90,0)
quad.texture(road)
road_position = 0
ground_position = 50
#add road and ground if getting near the end of road
def addRoad():
	global road_position, ground_position
	viewpoint_pos = viz.MainView.getPosition()
	#check to see how close the viewpoint is to the end of the road
	if road_position - viewpoint_pos[2] < 50:
		#add 50 meters of ground
		global ground_position
		groundcopy = ground.copy()
		groundcopy.setPosition([0,0,ground_position])
		ground_position +=50
		#add 50 meters of road
		for i in range(1,50):
			quadcopy = quad.copy()
			quadcopy.setPosition([0,.1,road_position])
			quadcopy.setEuler(0,90,0)
			road_position +=1
addRoad()
#call a timer every frame to check if road needs to be added
vizact.ontimer(0, addRoad)
#change the road texture on keypress
#vizact.onkeydown('1', quad.texture,road2)
#vizact.onkeydown('2', quad.texture,road)
vizact.onmousedown(viz.MOUSEBUTTON_LEFT, quad.texture,road)
#vizact.onmousedown(viz.MOUSEBUTTON_LEFT, quad.texture,road2)
def UpdateJoystick():
    #Get the joystick position
    x,y,z = joy.getPosition()
    #Get the twist of the joystick
    #twist = joy.getTwist()
    #Move the viewpoint forward/backward based on y-axis value
    if abs(y) > 0.0001: #Make sure value is above a certain threshold
        viz.MainView.move(0,0,-y*MOVE_SPEED,viz.BODY_ORI)
    #Move the viewpoint left/right based on x-axis value
    if abs(x) > 0.001: #Make sure value is above a certain threshold
        viz.MainView.move(x*0.1,0,0,viz.BODY_ORI)
    #Turn the viewpoint left/right based on twist value
    #if abs(twist) > 0.001: #Make sure value is above a certain threshold
    #    viz.MainView.rotate(0,1,0,twist,viz.BODY_ORI,viz.RELATIVE_WORLD)
#UpdateJoystick every frame
vizact.ontimer(0,UpdateJoystick)
def MOVE_SPEEDSC():
	global MOVE_SPEED, speedm, speedcon
	MOVE_SPEED = random.choice([0.15,0.2,0.25,0.3])
vizact.ontimer(5, MOVE_SPEEDSC)
#add textbox and set position on screen
text_speed = viz.addTextbox(parent = viz.SCREEN)
text_speed.setPosition(.15, .9 )
text_speed.fontSize (30)
old_posZ = 0
def showSpeed():
	global old_posZ, speed, speedm, speedcon
	current_pos = viz.MainView.getPosition()
	current_posZ = current_pos[2]
	distance = abs(current_posZ - old_posZ)
	#get speed in meters/sec
	speed = (distance/viz.elapsed())
	#get speed in mph
	#speedm = 4*(speed*3600)/1609.3
	#chnage multiplier to reflect gain change
	if MOVE_SPEED == 0.15:
		speedm = 6.666666667*(speed*3600)/1609.3
	if MOVE_SPEED == 0.2:
		speedm = 5*(speed*3600)/1609.3
	if MOVE_SPEED == 0.25:
	if MOVE_SPEED == 0.3:
		speedm = 3.33333333*(speed*3600)/1609.3
	old_posZ = current_posZ
	#enter speed in textbox rounded to 1 digit after decimal
	text_speed.message(str(round(speedm,1))+ 'MPH')
vizact.ontimer(0.25, showSpeed)
#Open file in path
filename = 'gainchangeprac_.txt' + str(subject)
def getPublishedPath(filename):
	#filename = 'adapt_.txt' + str(subject)
	publishPath = viz.getOption('Y:\backup\Vizard30\resources\road\_.txt','')
	if publishPath:
		return '/'.join([publishPath,filename])
	return filename
file = open(viz.res.getPublishedPath(filename), 'w')
def mytimer (num):
	#joy_pos = str(joy.getPosition())
	out = (str(round(speedm,1)) + '\n')
	file.write(out)
	file.flush()
	print out
viz.callback( viz.TIMER_EVENT, mytimer )
viz.starttimer( 0, 0.25, viz.FOREVER ) #capturing 4 times a sec
And it all appears to be working ok, but is difficult to verify for sure. Would you be able to cast your expert eye over this and let me know if I'm on the right track please?
Any help greatly appreciated!
Old 05-20-2010, 05:03 AM
Saz Saz is offline
Having carried out some testing on the code it seems that the program isn't changing the mph coding to reflect the associated change in accelerator gain.
Is the code in the wrong postition? Or have I just cocked it up completely with incorrect coding?
