Old 05-16-2009, 08:19 PM
Charlotte Li Charlotte Li is offline
tracker coordinates transform
I just start to use worldviz and there is a question confusing me. I am using Intersense IS-900 as the tracking system. The tracker's coodinate location is different from world coodinate. Is there a function can transform the tracker's coodinate? Do I need to write the transform matrix in the program?
Thank you!
Old 05-18-2009, 02:38 PM
If you just want to apply a global offset to the position of the tracker, then you can specify this when creating a link using the tracker. For example, if you wanted to move the Y position up 2 meters when linking the tracker to the viewpoint, you would use the following code:
viewLink = viz.link(tracker,viz.MainView,offset=(0,2,0))
viz.vertex coordinates lilio Vizard 6 05-16-2009 04:36 PM
Simple Head Tracker PHart Vizard 1 05-10-2009 05:35 PM
Does the vrpn7.dle tracker plug-in clear the udp buffer? michaelrepucci Vizard 2 09-19-2008 10:22 AM
Interface with Tobii Eye Tracker Uttama_vizard Precision Position Tracker (PPT) 1 12-12-2007 11:31 AM
Locating the Coordinates of Vertices for on the fly objects shivanangel Vizard 4 10-30-2006 08:28 PM
