Old 02-02-2009, 07:50 AM
Sandro Holzer Sandro Holzer is offline
node3d.visible(viz.OFF) Problem
Hello
I have a small problems with the node3d.visible command.
if I have 2 bodies like in the following code, when I swith off the visibility of the first body, then the second body also disapears.
Is there a workaround?
Thank you
Sandro
body1 = viz.add('body1.obj')
body2 = body1.add('body2.obj')
body1.visible(viz.OFF)
Old 02-02-2009, 10:56 AM
You can link an empty group node to your original parent object and then set the group node to be the parent of your child object. Then when you change the visibility of the original parent it won't affect the child. Here's an example.
box = viz.add('box.wrl',pos=[0,0,5])
#add empty group node and link it to the box
group = viz.addGroup()
link = viz.link(box,group)
#add the ball with the group node as parent
ball = viz.add('ball.wrl',parent=group,pos=[0,1,0])
#toggle box visibility
vizact.onkeydown(' ',box.visible,viz.TOGGLE)
#move box back and forth
moveback = vizact.goto(0,0,10,3)
moveforward = vizact.goto(0,0,5,3)
move = vizact.sequence([moveback,moveforward],viz.FOREVER)
box.addAction(move)
Old 02-03-2009, 02:22 AM
Thank You Jeff
I just have one more problem with this code.
In the line:
the position of the ball is in world coordinates,
I would need to give this position in relation to the box.
In my real code, there are a lot of bodies, all connected in something like a chain.
So if I have to calculate all the initial positions in world coordinates it would be a lot of work.
With the line
in my original code all this work is done by Vizard. (but visibility does not work the way I want)
Do you have an idea how to do this?
Sandro
Old 02-03-2009, 10:34 AM
the position of the ball is set in its parent coordinate system, the default is viz.ABS_PARENT. So the ball is always [0,1,0] in the group node's coordinate system which is the same as the box. If you try
print ball.getPosition(viz.ABS_GLOBAL)
you'll see its position is not [0,1,0] in the global coordinate system
Old 02-04-2009, 08:17 AM
Hi
Sorry, I am not able to work it ou by myself.
I added a small sample, and it should work like this:
there are 3 bars in a chain. The bar-body is attached
bar1 should rotate araund the vertikal axis (keys "t" and "b")
on the end of bar1, bar2 is connected and should rotate like a arm.
and on the end of bar2, bar3 is connected and should also rotate like a arm.
and then I want to switch the visibility of bar2
The first code is like I want it:
viz.clearcolor(0.1,0.1,1)
#ground = viz.add('tut_ground.wrl')
ANCHOR_POS= (0.6,1.8005,6)
bar1 = viz.add('bar2.obj',pos=ANCHOR_POS)
bar2 = bar1.add('bar2.obj')
bar2.translate([0.0,0.0,-1])
bar3 = bar2.add('bar2.obj')
bar3.translate([0.0,0.0,-1])
a = 0
b = 0
c = 0
def mytimer(num):
	global a,b,c
	if viz.iskeydown('t'):
		a = a + 1
		if a > 89:
			a = 89
		move()
	if viz.iskeydown('b'):
		a = a - 1
		if a < -89:
			a = -89
		move()
	if viz.iskeydown('f'):
		b = b + 1
		if b > 89:
			b = 89
		move()
	if viz.iskeydown('h'):
		b = b - 1
		if b < -89:
			b = -89
		move()
	if viz.iskeydown('z'):
		c = c + 1
		if c > 89:
			c = 89
		move()
	if viz.iskeydown('n'):
		c = c - 1
		if c < -89:
			c = -89
		move()
def move():
	euler = bar1.getEuler(viz.ABS_GLOBAL)
	euler[0] = a
	bar1.setEuler(euler,viz.ABS_GLOBAL)
	euler = bar2.getEuler(viz.ABS_GLOBAL)
	euler[1] = b
	bar2.setEuler(euler,viz.ABS_GLOBAL)
	euler = bar3.getEuler(viz.ABS_GLOBAL)
	euler[1] = c
	bar3.setEuler(euler,viz.ABS_GLOBAL)
vizact.onkeydown(' ',bar2.visible,viz.TOGGLE)
viz.starttimer(0,0.02,viz.FOREVER)
The following code is with the linked group:
First problem, the bar3 is not at the end of bar2 (you have to navigate back to look for it) this has something to do with the ANCHOR_POS of the first bar.
Second problem, bar3 follows bar2, but not the bar1.
link = viz.link(bar2,group)
bar3 = viz.add('bar2.obj',parent=group,pos=[0.0,0.0,-1.0])
a = 0
b = 0
c = 0
def mytimer(num):
	global a,b,c
		a = a + 1
		if a > 89:
			a = 89
		move()
		a = a - 1
		if a < -89:
			a = -89
		move()
		b = b + 1
		if b > 89:
			b = 89
		move()
		b = b - 1
		if b < -89:
			b = -89
		move()
		c = c + 1
		if c > 89:
			c = 89
		move()
		c = c - 1
		if c < -89:
			c = -89
		move()
def move():
	euler[0] = a
	euler[1] = b
	euler[1] = c
Old 02-05-2009, 01:11 PM
Here are two options. For your code without the group node you could replace
with something like
vizact.onkeydown('1',bar2.disable,viz.RENDERING)
vizact.onkeydown('2',bar2.enable,viz.RENDERING)
the third bar will continue to be rendered whether or not the second one is
in the code with group node and the link you could add
link.setSrcFlag(viz.ABS_GLOBAL)
after creating the link. The third bar will be in the correct position and you can toggle the visibility of the second bar.
Vertex shader performance problem Joran Vizard 2 11-17-2008 01:29 AM
export problem bazelaisr Vizard 2 05-28-2008 10:19 AM
5DT Data Glove 5 Ultra Problem bjgold Vizard 1 08-08-2006 04:08 PM
problem with female animations vmonkey Vizard 1 10-07-2005 10:36 AM
PROBLEM: Picture-in-Picture breaks textures?!? vcarlson Vizard 4 10-05-2004 04:22 PM
