Old 09-18-2009, 02:22 PM
purdue_vr purdue_vr is offline
Help! urgent problem
I am not able to execute any file. I get this error msg:
File "<string>", line 0, in ?
AttributeError: type object 'VizNode' has no attribute '_GetObject'
AttributeError: type object 'VizView' has no attribute '_GetObject'
AttributeError: type object 'VizAudio' has no attribute '_GetObject'
File "<string>", line 1, in ?
File "C:\Program Files\WorldViz\Vizard30\python\viz.py", line 18, in initplugins
pluginPath = getVizardPath() + 'plug-ins\\'
TypeError: unsupported operand type(s) for +: 'int' and 'str'
Old 09-18-2009, 03:24 PM
It sounds like Vizard was not installed correctly. Shut down Vizard and check the task manager and make sure winviz.exe is not running. Then re-install Vizard.
Vertex shader performance problem Joran Vizard 2 11-17-2008 02:29 AM
export problem bazelaisr Vizard 2 05-28-2008 11:19 AM
5DT Data Glove 5 Ultra Problem bjgold Vizard 1 08-08-2006 05:08 PM
problem with female animations vmonkey Vizard 1 10-07-2005 11:36 AM
sound problem alaa Vizard 7 09-02-2005 02:13 PM
