Old 04-16-2010, 01:34 PM
whj whj is offline
Shader for blurring
I had this sample code for blurring. But I messed it up and don't know where is the problem. It should can enable fullscreen blurring, and larger kernel create more blur. Can somebody help me to fix it and explain it? Thanks a lot.
viz.add('tankmaze.wrl')
size=512
kernel=3
d = viz.Data()
d.scale = 1.0
d.created = False
d.created = True
d.passes = []
#Uniforms for shaders
srcImageUniform = viz.addUniformInt('srcImage',0)
blurScaleUniform = viz.addUniformFloat('blurScale',1.0)
blur_source = """
uniform sampler2D srcImage;
uniform float blurScale;
void main(void)
	vec4 color = vec4(0,0,0,0);
	%code%
	color.a = 1.0;
	gl_FragColor = color;
#Calculate weight and offsets for blur code
weights = []
offsets = []
mid = float(kernel - 1)
kernel *= 2
for i in xrange(0,kernel,2):
	offsets.append( ((i-mid) / 2.0) * (1.0 / size) )
	x = (i - mid) / mid
	weights.append( 0.05 + ((-(x*x) + 1.0) / 4.0) )
#Normalize weights
total = sum(weights)
frac = 1.0 / total
weights = [ frac * x for x in weights]
#Create blur code for shaders
horz_blur_code = []
vert_blur_code = []
for w,o in zip(weights,offsets):
	horz_blur_code.append('color += ( texture2D( srcImage, gl_TexCoord[0].xy + vec2( %f*blurScale, 0.0 ) ) * %f );'%(o,w))
	vert_blur_code.append('color += ( texture2D( srcImage, gl_TexCoord[0].xy + vec2( 0.0, %f*blurScale ) ) * %f );'%(o,w))
horzBlurShader = viz.addShader(frag=blur_source.replace('%code%','\n'.join( horz_blur_code ) ))
vertBlurShader = viz.addShader(frag=blur_source.replace('%code%','\n'.join( vert_blur_code ) ))
for eye in [viz.RENDER_LEFT,viz.RENDER_RIGHT]:
	#Render textures for ping-ponging
	tex1 = viz.addRenderTexture()
	tex2 = viz.addRenderTexture()
	Pass 1 renders the normal scene to a texture
	pass1 = viz.addRenderNode(size=[size,size])
	pass1.attachTexture(tex1)
	pass1.setOrder(viz.PRE_RENDER,-5)
	pass1.disable(eye)
	Pass 2 renders the texture from pass 1 onto a quad.
	The quad has a shader attached which blurs the texture horizontally.
	pass2 = viz.addRenderNode()
	pass2.setHUD(0,200,0,200,renderQuad=True)
	pass2.setSize(size,size)
	pass2.setBuffer(viz.RENDER_FBO)
	pass2.setOrder(viz.PRE_RENDER,-4)
	pass2.attachTexture(tex2)
	pass2.texture(tex1)
	pass2.apply(horzBlurShader)
	pass2.apply(srcImageUniform)
	pass2.apply(blurScaleUniform)
	pass2.disable(eye)
	Pass 3 renders the texture from pass 2 onto a quad.
	The quad has a shader attached which blurs the texture vertically.
	pass3 = viz.addRenderNode()
	pass3.setHUD(0,200,0,200,renderQuad=True)
	pass3.setSize(size,size)
	pass3.setBuffer(viz.RENDER_FBO)
	pass3.setOrder(viz.PRE_RENDER,-3)
	pass3.attachTexture(tex1)
	pass3.texture(tex2)
	pass3.apply(vertBlurShader)
	pass3.apply(srcImageUniform)
	pass3.apply(blurScaleUniform)
	pass3.disable(eye)
	Pass 4 renders the final blurred texture to the screen
	pass4 = viz.addRenderNode()
	pass4.setHUD(0,200,0,200,renderQuad=True)
	pass4.setOrder(viz.POST_RENDER,-1)
	pass4.texture(tex1)
	pass4.disable(eye)
	#Save render nodes and blur uniform
	d.passes += [pass1,pass2,pass3,pass4]
d.blurUniform = blurScaleUniform
d.blurUniform.set(d.scale)
[ p.visible(True) for p in d.passes ]
viz.MainScene.visible(0,viz.WORLD)
Old 04-19-2010, 11:28 AM
whj whj is offline
I just realized that the code works well on the other computer in our lab. I guess that depends on graphic card.
So my next question is, how can I apply the blurring to part of my view? Like in a circle area in the middle?
THANKS A LOT!
begginer tutorial shader? Darkmax Vizard 1 04-15-2010 04:26 PM
Multiple Textures for Diffuse and Specularity Shader Issue shivanangel Vizard 1 05-11-2009 10:44 AM
Specular Shader Issue shivanangel Vizard 2 05-06-2009 11:08 AM
Vertex shader performance problem Joran Vizard 2 11-17-2008 01:29 AM
Fur Shader djdesmangles Vizard 1 05-29-2008 09:37 PM
