Old 05-28-2008, 10:02 AM
Question Fur Shader
Hello Wizards,
I would like to test the GLSL Fur shader from ATI RenderMonkey in Vizard, but I don't understand how it works (in Vizard) ... There're severals passes and everything...
Thanks...
viz.FOREVER !!
D.
Old 05-29-2008, 09:37 PM
I've never used RenderMonkey, so I'm not familiar with how it works. Does it output a GLSL shader, or does it have its own format which specifies all the passes and shaders? You can definitely perform multi-pass rendering with Vizard. And Vizard supports GLSL, so technically this should be possible. What exactly do you need help with?
3DS Max Export: automatic shader assignment for various maps emlyn Vizard 0 03-14-2008 09:29 AM
Npr nige777 Vizard 5 11-29-2007 03:03 PM
Image blur jrodman Vizard 19 12-15-2006 03:48 PM
Multi-Texturing... k_iwan Vizard 14 09-09-2006 09:01 PM
