Old 02-02-2009, 07:50 AM
Sandro Holzer Sandro Holzer is offline
node3d.visible(viz.OFF) Problem
Hello
I have a small problems with the node3d.visible command.
if I have 2 bodies like in the following code, when I swith off the visibility of the first body, then the second body also disapears.
Is there a workaround?
Thank you
Sandro
body1 = viz.add('body1.obj')
body2 = body1.add('body2.obj')
body1.visible(viz.OFF)
Vertex shader performance problem Joran Vizard 2 11-17-2008 01:29 AM
export problem bazelaisr Vizard 2 05-28-2008 10:19 AM
5DT Data Glove 5 Ultra Problem bjgold Vizard 1 08-08-2006 04:08 PM
problem with female animations vmonkey Vizard 1 10-07-2005 10:36 AM
PROBLEM: Picture-in-Picture breaks textures?!? vcarlson Vizard 4 10-05-2004 04:22 PM
